03-19-2017, 11:26 PM | #511 | |
Fresh gas? Clean tank? Clean tank and/or fuel filter? (there's a filter in the tank at the petcock) Good battery? Spark plug-right one? correct gap?
03-20-2017, 01:13 AM | #512 |
i always just start riding with the choke on and then flip it down while riding. mine is still cold natured too. aint got time for no warming up nonsense
03-23-2017, 09:45 AM | #513 |
It's been quiet around here
It has been quiet around here for a while. ARH is waiting for information on the latest greatest thing from China since sliced bread. It is hard to accept the tried and true vs the new and exciting, so I'm waiting for enough reports to come in on the latest wonder bikes from China, looking for ways to weasel their way into our wallets. It remains to be seen how much better the Enforcer is compared to the Hawk, for example. Certainly the less hassle about registering them is a plus. In those states that cause hassles. A lot of the hassle can be avoided if you make sure the MCO from the distributor states it is a motorcycle, instead of a dirt bike. I must say, so far, the first reports on the Enforcer are very good. But I think I will wait on a larger sample before I jump on the bandwagon. As to the others coming on the market, to me the most important point is wheel size. It is difficult to get all of the different tread types in any size other than 21inch, or 18 inch...ARH
03-26-2017, 08:03 PM | #514 |
Spokes and tires.
A rider posted on this forum that he went for a ride the other day, and the rear tire was flat. OK, tires go flat, from time to time. But what he found when he broke down the tire was disturbing. What he found was some kind of oily, slippery fluid inside the wheel, coated on the tube and on the inside of the tire. This came from the factory, as it was a new bike. He thinks the slimy tire slipped on the rim, and pinched the tube. Could be, I guess. I suggest that when you assemble the bike you unscrew the the Schroeder valve to let the air out, and then use a tire spoon to break the bead loose in one spot and see if there is any of that stuff inside your tire. If there is, better break that tire down and get every trace of whatever that stuff is totally cleaned from the tire, the tube, and the inside of the wheel. I hope this was a one time screw up at the factory, and we never see it again, but people need to be aware this happened once already, so could happen again...ARH
03-27-2017, 08:30 AM | #515 | |
03-27-2017, 09:36 AM | #516 | |
03-28-2017, 04:38 PM | #517 |
About ARH...
I guess I think that I should explain that I only offer suggestions on here based on 67 years of motorcycling. and I occasionally dredge up reminices of various (English) bikes I have been impressed by. Or deafend by. Or terrified by. Or requiring constant fixing. Ariel Red Hunters and Square Fours were the best motor cycles I've ever ridden. Better than BMW's? Yes. For me. Triumphs could terrify me. I'm going to recite Slammin' Sammy Tanner (also known as Stuttering Sammy Tanner) on Triumph frames. After turning a couple of hot laps at Ascot, he breezed into the pits, shaking his head, "B-B-B-Boy, this spagetti framed Triumph wants to walk me all over the race track." "When I turn it on, coming out of either corner, I never know if I'm going to come out high, low, or where. Could get interesting when there are 16 other bikes out there". Deafend by: Greeves scramblers with a 9 inch megaphone exhaust coming right out of the exhaust port. Constant fixing: A James Cadet 125 two stroke. What a pile of bits that was. Another terrifying one, A Vincent Black Shadow with a grabby clutch. Trying to cross 4 lanes of traffic on Ventura Blvd in Woodland Hills, California.
03-29-2017, 10:27 PM | #518 |
That reminded me of you military bike post.
03-29-2017, 10:46 PM | #519 |
Yeah it does, doesn't it. Thanks for finding it. I've never seen it before....ARH
03-30-2017, 02:58 AM | #520 |
"then theres a great sorting out!" been there done that! usually the first turn in motocross.
03-30-2017, 07:30 PM | #521 |
rims and spokes
Several riders have posted on this forum about changing rims on some C/B's in order to get 21 inch fronts and 18 inch rears. Now to help you guys out, I've found a couple of tutorials on lacing and trueing wheels in the simplest procedure I've ever seen. Now this guy is a little hard to understand because of his accent and choice of words, so watch them both over and over until you understand how simple it is if you do it right. It's very logical, once you get your mind wrapped around what he's telling you and showing you. Now don't get all excited because he's talking about building a BSA B-25 trials bike. Wire wheels are wire wheels, no matter what they are mounted on. So, Britannia Motor Cycles, BM 250 Trials, part 10 (1), and part 10 (2). Watch and learn.....ARH
03-30-2017, 08:55 PM | #522 |
Thanks for posting this very educational I learned a lot. He sure makes it look easy I am sure if I tried it would not go as quick but I Think I could get it done.
03-30-2017, 10:21 PM | #523 |
I know you can get it done. He's teaching in all of his videos, not showing off. He wants you to succeed. I'm glad you found it educational...ARH
04-01-2017, 08:11 AM | #524 |
Heads Up Alert!
One of our members had his drive chain jump off the drive sprocket, and he can't shift it out of low gear. He has 3000 miles on the bike, so I don't know if this will be covered under warranty. He is pretty likely going to have to split the cases in order to fix this. Or try to find one that's been in a highway accident, but still with a good motor to try in his bike. For the rest of us, it seems to me, this is a warning to buy and install a new chain! Replace that nickel-dime chain that comes on these bikes sooner, not later. I can't stand the sight of grown men crying!...ARH
04-01-2017, 08:43 AM | #525 |
What is the best way to set / check the chain tension for these bikes?
