Old 04-09-2021, 09:00 PM   #496
With enough duct tape, anything is possible!
First Rule of Aviation:
The Stable:
2005 Yamaha V-Star 650 - SOLD
2015 Suzuki DR 650
2015 RPS Hawk 250 - SOLD
2016 Ural Gear Up
Old 04-18-2021, 01:16 PM   #497
wheelbender6's Avatar
Name:  irish sidecar res.jpg
Sidecar passengers deserve their own special drink.
Old 04-19-2021, 11:41 AM   #498
Sport Rider's Avatar
Guess what's back on the road!!!!!????!!!!!
File Type: jpg 175166038_770403693609608_8973816670549803956_n.jpg (79.7 KB, 207 views)
Old 05-02-2021, 08:20 AM   #499
cheesy   cheesy is online now
cheesy's Avatar
Windiest ride ever yesterday.
Mrs. C wanted to do an ice cream ride and she said let's take the motorcycle. The wind was howling out of the southwest. We are talking 50 mph gusts. I can't even use 4th heading west or south. So it's 3rd and 4600/4800 rpm to make maybe 50 mph. The Maggot would shrug at 4600 and plod on, but the Ural has a 5800 red line. Trying to keep the speed down heading north or east was somewhat of a battle, too.
Suffice it to say, after the buffeting for the 50 miles we rode, I was beat.
When I was younger and doing 25K time trials on a bicycle, we'd call that 'not enough motor going out and not enough gear back' on windy days.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 06-05-2021, 06:23 PM   #500
cheesy's Avatar
Approaching a milestone. 31068 miles equals 50,000 kilometers.
I still have folks tell me what a POC* Urals are, that the engine will grenade because of the spin on filter upgrade, my hitch tube will fail and cause an accident. Bless their hearts. The little beast just keeps on chugging along.
*I will admit that the speedometers can be crappish, though one guy at SS has rolled his original speedo over twice.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 06-06-2021, 08:57 AM   #501
Landsvw   Landsvw is offline
Landsvw's Avatar
I forgot to tell you! On the 27th of May I was driving up to Eugene, 90 miles away, and going down the interstate was a Ural with a side car! I think it was blue in color? Pretty sure he had bugs in his teeth from smiling. Anyway, thought of you!
1988 Kawasaki KLR250
1969 Honda Z50 silver tag
2002 Ford F-350 7.3 diesel
1975 Corvette
2017 Chevy Bolt
“Throttle twisting geek” -LFN
Old 07-05-2021, 09:54 AM   #502
cheesy's Avatar
I did the 50,000km service yesterday. I've been run so hard that it took almost an entire year to knock out the 2,000 miles since the last service. I have the deep sump, so I can push it a bit farther. Anyway, engine oil, filter, and final drive. Tranny is every other oil change. Since I rebuilt the final drive a few years ago, it's always a good feeling when the gear lube drained out is almost the same color as the new lube going in.
Only headache was that I replaced the Mann 75/3 filter with a Hi-Flo filter that is about 1mm taller than the Mann filter. That made it a bit of a struggle to get the filter over the the crossover pipe. I glared at the filter and it slipped into place.
I was going to rotate the pusher and hack tires but both are so worn that I'll just replace both tires this fall.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-06-2021, 11:45 AM   #503
One of my buddies from the airport I fly out of called me late saturday night, and said that they needed some help. They were in the walmart parking lot with a lady who had an older carbureted Ural, and it wouldn't start. At first they thought the battery was dead, so they tried push starting it, and the back tire just completely locked up. Then they noticed fuel dripping out the left side carb. I pulled the plug, and sure enough the whole cylinder was full of go-juice. I checked the oil, and the crankcase was also full of gas floating on top of what was originally a proper amount of oil. I took the other plug out, and it was completely dry, although it looked like it was running just a bit rich. I tried to turn the engine over with both plugs removed and it didn't budge. Uh-Oh... I think that with the cylinder full of gas, when they tried to push-start her, it bent something important in the engine. Not sure how it turned out for her in the end, I waited with her until the tow-truck showed up, and then headed back to the house.
The Stable:
2015 Suzuki DR 650
2016 Ural Gear Up
Old 07-06-2021, 03:00 PM   #504
cheesy's Avatar
Yup. Open petcock and a carb float stuck open. Flooded the cylinder with gas and hydro locked. Once the starter button is poked, the damage is done and a connecting rod is bent or the three piece crank gets twisted out of whack. Rebuild time.
This isn’t an issue with fuelies but on carbed models it can be. Especially older rigs.
That’s why I prefer to kick start my rig. The starter has enough torque to cause a lot of boo boos. If I can’t kick it over, there’s a problem and time to stop and find out why. So far, so good.
Sounds like the lady will need a “Sergai will fix it”.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-06-2021, 04:52 PM   #505
Oddball Matt   Oddball Matt is offline
Funny that, currently listening to an audiobook about a spaceship with a Russian chief engineer, when reading that I can actually hear ensign Vladimir Kaminetzky go oh bozhe moi
2004 Longjia Grido 50 scooter
1999 Cagiva Mito 125 Evo, Yamaha XV125 engine, Ducati SS fairings, getting turboed
1993 Yamaha GTS 1000
Ex:Bashan BS200-S7 `07 Streetfighter-quad
Old 07-07-2021, 04:03 AM   #506
Lucky for her her son owns a motorcycle shop in Newnan, about a thirty minute ride from Carrollton. Her son was out of town that night, but she had mentioned he has a trailer and will come pick it up. She had also mentioned that he had replaced the carbs about six months and a whole lot of miles ago. This was the first problem she had with it, but I figure she used up an entire years' worth of problems with this one... I need to get mine into a shop. It doesn't matter how many times I kick mine over, I just cannot get it to start with the kickstarter. I would much rather go for the 'authentic' look, and use the kick starter, but even getting it started with the electric starter takes time (and a whole lot of swearing). That's the downside to having a fuel injected rig; I can't work on it in the garage with the radio playing away in the corner. It needs to go to the shop...
The Stable:
2015 Suzuki DR 650
2016 Ural Gear Up
Old 07-07-2021, 06:42 AM   #507
cheesy's Avatar
Your rig has the Electro-jet system. I understand they’re a beyotch to kick start. A bunch of guys at Soviet Steeds came up with an interface cable and software to beat up on the ECM so it will behave a bit better. As a carb guy, it looks like sorcery.
Ural now has a Keihin Fuel Injection upgrade kit available to replace the Electro-jet system on the 2014-2018 models. Just $3K and a lot of time to install.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-07-2021, 02:49 PM   #508
Everything that happens inside the fuel injection brain box is black magic and witchcraft as far as I'm concerned. Honestly, the $3k might be worth it to get that beast up and running the way it should. I dunno. Maybe I'll look into it. Any idea where I can find some info on the new system?
The Stable:
2015 Suzuki DR 650
2016 Ural Gear Up
Old 07-07-2021, 03:14 PM   #509
cheesy's Avatar
Here you go.
https://www.uralne.com/gen-2-efi-thr...4-2018-models/
Don't tell your wife I showed this to you.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-07-2021, 03:16 PM   #510
cheesy's Avatar
There's also this.
http://m2boxer.com/us/ural-750cc-2014-2018
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
