Old 02-10-2016, 07:59 AM   #4771
kohburn   kohburn is offline
kohburn's Avatar
I highly recommend a voltage monitor light. since I added one to me versys it has helped me recently. when the bike is off and not running the light slowly blinks yellow or red indicating a normal battery strength, if it goes full red then the battery is low. with it running it is solid green. blinking green if I'm using a bunch of accessories but still acceptable charging voltage. if it blinks yellow or red then it is not charging.
yesterday it warned me that it couldn't keep up so I had to turn down the heat on my heated grips.
i'll see if I can dig up a link to one like I have.
edit:
this is the exact one I have
http://www.ebay.com/itm/190944256307...%3AMEBIDX%3AIT
I leave it on setting 3
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 02-10-2016, 08:05 AM   #4772
jbfla   jbfla is offline
Since adding a pigtail for a heated jacket liner, I've been thinking along the same lines.
Where/ how did you mount the voltage monitor?
jb
2014 XT 250........
Old 02-10-2016, 08:22 AM   #4773
willy dog   willy dog is offline
willy dog's Avatar
Originally Posted by surfndirt View Post
Woohoo!! Paid for my '16 red RX3 in full yesterday, so excited. CSC is putting on a 13t front sprocket, and K270's on for no extra labor charge!! Ryan and the crew are awesome!
The only thing I'm worried about is the battery failing and leaving me stranded somewhere someday - should I get a new upgraded shortly after I get the bike? Is the '16 battery any different from previous years?
i think they changed batt. after 5000 mile west coast trip got my bike in november been under cover but outside no starting prob. even when below zero for few days congrats on new bike
Peace and Zong Life
Old 02-10-2016, 08:37 AM   #4774
kohburn's Avatar
jb
small hole drilled in a dash plate. black wire to ground, red wire to battery. it blinks yellow (good charge on battery) or red (slightly low charge on battery) with the bike off just like those alarm indicator led's if you walk up to the bike and the LED is solid red you may have trouble starting or off then you have a dead battery
you could also tap the red off a ignition switched line if you only want it on when you are on the bike.
- 2016 CSC TT250
Old 02-10-2016, 03:13 PM   #4775
Thanks for the explanation.
Is the light visible in bright sunlight?
jb
2014 XT 250........
Old 02-10-2016, 06:16 PM   #4776
surfndirt   surfndirt is offline
surfndirt's Avatar
Sweet! Thanks!
'16 Red RX3, K270's, 13t Front, Fog lights, Tusk Bar Risers (4K mi.)
'82 Suzuki SP250 (11k Miles)
'85 Honda Rebel 250 (Sold April 2016)
Old 02-10-2016, 09:41 PM   #4777
kohburn's Avatar
jb
its not as noticeable but yes still visible.
- 2016 CSC TT250
Old 02-11-2016, 03:53 PM   #4778
G19Tony   G19Tony is offline
G19Tony's Avatar
Results from Dynojet.
Baseline is red.
Honda CB300R ABS
Old 02-11-2016, 05:48 PM   #4779
Thanks for posting the dynoJet results, Tony. It seems the stock fuel map is pretty good.
Old 02-11-2016, 06:47 PM   #4780
G19Tony's Avatar
Yea, it's netting 1hp, but I do like the AF ratio. They're messing with some O2 sensors. I'll get it back on Monday and they want me to ride for a bit.
Honda CB300R ABS
Old 02-11-2016, 10:11 PM   #4781
kohburn's Avatar
yeah that may result in improved fuel efficiency
- 2016 CSC TT250
Old 02-12-2016, 07:14 AM   #4782
Dualsport Chic   Dualsport Chic is offline
Dualsport Chic's Avatar
Let's Talk Tires
Checking in with the RX3 owners on their tire choices for their bikes. I am looking for something like a Heidenau K60 as my next tire once the OEM's wear out but am noticing there is not alot available in the 130/70-17 & 110/90-18 combo that is currently on the bike. I'm not going with the 19" front as I need to keep the seat height as low as possible as I am vertically challenged.
Looking forward to hearing what options are out there.
Carpe Diem
IBA#65836
2005 BMW F650gs
2008 Yamaha XT250
2013 Yamaha XT250
2009 Suzuki Gladius
Old 02-12-2016, 07:33 AM   #4783
Huck369   Huck369 is offline
Huck369's Avatar
Spud has a good Tire list here:
http://www.chinariders.net/showthread.php?t=14566
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 02-12-2016, 10:05 AM   #4784
willy dog's Avatar
only have 250miles on bike not a big fan of stock tires once off the pavement i switched to the kendas the price was right
Peace and Zong Life
Old 02-12-2016, 10:40 AM   #4785
If you want to keep the saddle height low, I recommend the Shinko 244, size 3.00-18, for the front tire. This is my current front tire, and it performs well.
A smaller rear tire you might like is the Shinko 700, size 5.10-17.
If you want a more aggressive tread, the Shinko 244, size 5.10-17 is very nice, but it will raise the saddle height about 1/2-inch more than the Shinko 700.
