Old 04-10-2011, 09:44 PM   #31
JTCAndrew   JTCAndrew is offline
Relooking at your Pictures The Speedo on the LXT Looks alot like the "Q" - Does that really have a HONDA Engine on it?
Andrew - Jamestown, PA 16134
YouTube Videos:
http://www.youtube.com/user/Jtcomp2009#p/u
2009 Qlink XF200 Supermoto
1982 Honda CM200 Bobber - SOLD
2003 JEEP Liberty SPORT = 3" Lift
2002 Chevy Trailblazer LTZ - Family Cruiser
Old 04-10-2011, 09:50 PM   #32
I think the speedometers are exactly the same, Andrew. The previous owner cracked the stator cover, and replaced it with an NX250 part.
Old 04-10-2011, 09:53 PM   #33
So It's A honda Clone? Intresting. If it is can't be to bad.....Looks like the Left side of the speedo is a Bit Different other then that the same.....
YouTube Videos:
Old 04-10-2011, 10:03 PM   #34
The Xingyue/LXT 400 is mostly a Honda clone, Andrew. The bottom end of the engine is cloned from the Honda NX250. The top end of the engine is from a Rotax, ATV engine. The frame and swingarm are reputed to be cloned from the Honda XR400. The forks are Chinese, and the saddle is suspected to come from Hades.
Old 04-10-2011, 10:04 PM   #35
Originally Posted by FastDoc
PP says the plastics and frame are XR400 clones, so XR400 plastics and tank should fit.
That means that '96 to '04 XR250 parts will fit as well. Same bike, AFAIK.
That's what I think. I'm starting to think of this bike as a Honda clone with a Rotax cylinder and head. That will help with spare parts. I also would use XY Canada and/or Saga Canada if I needed anything. The prices for parts are amazingly low for this bike. :P
Old 04-10-2011, 10:06 PM   #36
Did u get any pics of the Husaberg? Sounds Mean..... :?:
Will post in the Other Stuff Forum in a minute. Stupid fast bike. Husaberg and KTM are the same. Fuel injected, top shelf everything. Way more bike than I need, but it would make a cool D/S.
Old 04-10-2011, 10:08 PM   #37
The saddle is suspected to come from Hades.
LMAO Spud!
If I kept this bike I'd be considering eBay for XR400 saddles... :roll:
Old 04-11-2011, 01:06 AM   #38
It seems to me that you could swap an XR400 cylinder, piston and head onto that bottom end, if you were so inclined. The XR400 engine runs all day long without coolant, but it does use a small heat exchanger behind the headlight to cool the oil.
Where is the dipstick on the XY? Is it on the engine? On my XR250R, it's in front of the gas tank.
Old 04-11-2011, 09:22 AM   #39
fishman10's Avatar
pp400lxt
doc ,please check your lower radiator hose ,mine is cracked and or rotten at both ends the chinese rubber is very poor ,and I have gotten no reply from pitster or xingyue canada ,, so if anyone knows of a suitable replacement ,,plus how did this all begin ? Is that daddy's pp400? I may keep mine now ,,,Iwas seriously gonna sell it cause we know so little bout these and what might fit ,,,but now since doc is on the case I feel better!
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic.
Old 04-11-2011, 09:43 AM   #40
fishman10's Avatar
pp400
xr 400 tank probly won't work ,cause of the radiator ,but its worth a look
Old 04-11-2011, 10:44 AM   #41
A little creativity and maybe a MIG welder could move a rad.
Fish, have you tried bulk heater hose from the local parts store? If you need an elbow in it, you could always insert one and secure it with gear clamps.
Old 04-11-2011, 11:08 AM   #42
fishman10's Avatar
pp400
yes weld its got some pretty sharp bends in such a short length,, think the plastic elbows will hold up?
Old 04-11-2011, 11:14 AM   #43
This bike is a wt sump. The oil fill and dipstick are on the right side of the engine.
I'll leave it to the next owner to modify. I am enjoying it as is right now. Fired right up this AM. The 'trick' is to just pull the enricher a tiny bit, she starts right up and is good to ride with no stumbling in a minute. Temps are in the mid 40's this AM, FWIW.
Old 04-11-2011, 11:20 AM   #44
Re: pp400lxt
I checked the hoses they are fine. I may replaace them with hoses from the auto parts store though.
I was hoping XY Canada would be a good source. What's up there?
This was Daddy's XY. I hope it treats me better than it treated him. So far so good...
Old 04-11-2011, 11:35 AM   #45
fishman10's Avatar
pp400
I emailed both pitster and xingyue canada as well as xingyue corp inquiring about gettin some parts particularlly the radiator hose,,no one has responded.
