View Poll Results: Which Zong tank plastic do you prefer?
Factory Tank Plastic 26 47.27%
3-Fin Tank Plastic Mod 2 3.64%
2-Fin Tank Plastic Mod 2 3.64%
No-Fin Tank Plastic Mod 5 9.09%
Clarke 4.1 Gallon Fuel Tank 20 36.36%
Voters: 55. You may not vote on this poll
Old 08-23-2009, 12:10 AM   #31
Spud, I'm going to need an aftermarket tank option before I can vote.
I am not ignoring your response, WG. I have done a significant amount of research regarding the aftermarket tank options for the Zong. However, I need to experiment a little before I present my findings in another thread.
Old 08-23-2009, 12:59 AM   #32
Once the mounting tab broke off my tank shroud, I decided I had nothing to lose by experimenting a bit with different shapes.
None of the modifications I have made to my Zong are irreversible; I can easily return my motorcycle to stock form, if I desire. Therefore, I can easily buy new tank plastic, and return to the original configuration.
I am going to take Cal25's suggestion, and make the following section. I will post photos after the cutting is done.
The retouched photograph shown below should approximate the final result.
Old 08-26-2009, 12:17 AM   #33
I completed my tank plastic cuts. In addition, I decided to trim the rear side plastic as well.
Here is a photo taken in an Idaho wheat field.
This photograph was taken with an Idaho thunderstorm occurring in the distant mountains. Fortunately, I avoided getting wet.
Here is a view from the 4 o’clock position.
Here is a view from the 7 o’clock position.
Should I keep the tank plastic orange, or paint it black? If I keep the tank plastic orange, should I keep, or remove the lettering?
Old 08-26-2009, 12:28 AM   #34
Boy, the sun didn't change much between four and seven o'clock. :wink:
Ditch the lettering and let's see how it looks. Don't paint the plastic yet.
Old 08-26-2009, 12:57 AM   #35
Boy, the sun didn't change much between four and seven o'clock. :wink: ...
:roll:
...Ditch the lettering and let's see how it looks. Don't paint the plastic yet.
OK. I ditched the lettering.
Old 08-26-2009, 02:09 AM   #36
It looks great, Spud. Ride it!
Old 08-26-2009, 02:17 AM   #37
The black tank plastic would appear somewhat similar to the retouched photograph shown below.
Old 08-26-2009, 02:17 AM   #38
AZ200cc   AZ200cc is offline
It's Your bike, If You like it, it's all good
Old 08-26-2009, 02:35 AM   #39
Thank you for the suggestion to trim the rear side plastic, AZ! The Zong's rear end looks a lot slimmer after I trimmed it a bit.
Old 08-26-2009, 02:57 AM   #40
Originally Posted by SpudRider
You offer an excellent alternative when you suggest trimming the plastic all the way back from the front of the fuel tank to the lower rear. However, I can't think of a good tool that would accomplish that task. :( I used a hack saw and Dremel tool to remove the plastic on the front of my tank shroud; it was not an easy task. :( I don't think a hot knife would work well cutting this plastic. Perhaps the best tool to use would be a coping saw. :?:
...You could also try judicious use of a flap disc on a 4 1/2" angle grinder. Sneak up on it, and you could sand away all the offending material. Stop short of your final cut and hand sand the last bit. That's all I can come up with…
Thank you for the suggestion, WG. I ended up using a cutting wheel on a 4 ½” angle grinder to make the first, rough cuts. I made the final, precision cuts with a cutting wheel on my Dremel tool.
I am pleased with the results of my experiment. My YamaZong is now lighter, with less wind resistance than before.
Did someone also mention aftermarket fuel tanks as an option? Hmmmm…
Old 08-26-2009, 03:06 AM   #41
dwholler   dwholler is offline
Spud,
How about painting the tank orange to match the remaining orange in the shroud like this?
Old 08-26-2009, 08:30 AM   #42
Jim   Jim is offline
Isn't part of the reason for the tank shroud out the front to scoop the air into the front of the tank and direct it down to the air cooled engine? I could be wrong, and I don't know what I am talking about, thats why I am asking... Either way though I still prefer stock. That said, nice pictures, I like the 4 oclock one best.
"Be excellent to each other"
Old 08-26-2009, 08:47 AM   #43
Cal25   Cal25 is offline
Before going ahead and painting the plastic, I would first try some paint on the cut off remnants of plastic. Most important would be how the paint would react to slops and spills when filling the tank with gas. I know other have had problems with the paint bubbleing up after a small spill. Perhaps some paints or clear coats would preform better than others? That pproblem is what has kept me from trying to get rid of the labels on my tank cover. I know that at least the area of the decals have clear coat on them and as of now I have not had problems with gas.
I second the thought of re-painting the actual tank onder the cover.
Old 08-26-2009, 08:52 AM   #44
frostbite   frostbite is offline
Is there any reason to keep the shroud? I'm curious what it would look like without. The Lifan's not so good (IMHO).
Frostbite
"The beatings will continue until moral improves"
Old 08-26-2009, 11:46 AM   #45
IMHO, the original plastic was there to emulate the current Jap bikes that have radiators. I tend to agree with Spud that the original plastic creates more wind resistance than anything.
Spud, if you paint that plastic, it will lift the moment gas gets near it. Painting the tank to match the orange plastic does have a certain appeal.
