Old 06-21-2008, 05:22 PM   #31
jayg   jayg is offline
Originally Posted by kczukiman
I liked Kats idea so I copied it.
Kman - did you put some type of support under the part of you actionpacker that hangs over the rack?
Old 06-21-2008, 05:36 PM   #32
katoranger's Avatar
Mine is attached directly to the rack itself. No additional support pieces used.
The plastic is pretty ridgid and the bottom is sturdy. I put over a 100lbs of stuff in there. I don't recommend trying that. I have also strapped many items to it.
It has taken falls and hits and still looks good.
Allen
Old 06-21-2008, 06:08 PM   #33
I finally decided on a luggage and here it is...thanks to Kato.
How I connected it.
I need to add washers for a little more support.
Old 06-21-2008, 06:23 PM   #34
katoranger's Avatar
Action Packed?
Allen
Old 06-21-2008, 06:51 PM   #35
kczukiman   kczukiman is offline
Looks good jayg.One thing you may want to do is add some fender washers to the inside of your action packer.It will help destribute the pull a little better.I put cross braces totaly across the inside from bolt to bolt to help distribute the pull.
I like the way you attached it.Good job.Another Katorised bike....
Kman
2007 HI-BIRD 250
2007 Vbike V4S 250
Old 06-21-2008, 07:02 PM   #36
Can you post some pics of the braces you added?
Old 06-21-2008, 07:49 PM   #37
katoranger's Avatar
I just have some plain washers, but I am sure the extra bracing helps.
Mine has stayed for 6500 miles now.
Allen
Old 06-21-2008, 08:47 PM   #38
SpeedSouth   SpeedSouth is offline
Originally Posted by Brainsquishy
I am about to order one of the JCWhitney MATTE BLACK TRAVEL TRUNKS and wondered if you wish you had bought the larger one. I think you got the medium size, right?
Looks great. The Ninja makes me drool.
Thanks
On the trunk..to be honest, I haven't used it enough to really form an opinion. I do have the medium, and it will NOT hold my helmet...so I can understand wanting the larger size. I had some reservations about the mounting plate, which is part of the reason for me ordering the medium, but if I had it to do over again, I would more seriously consider the larger model.
Hope that helps...
2008 American Lifan LF200 GY-5 (930 km) - Sold
2007 Kawasaki EX250 - Sold
2006 Kawasaki EX650R - My new ride!
2005 Kawasaki EX250 - A new project
Old 06-21-2008, 10:50 PM   #39
Brainsquishy   Brainsquishy is offline
Do you think a larger one than the one you have would be too big or still OK? I'm really leaning towards the larger of the two. Thanks for your input.
http://www.jcwhitney.com/MATTE-BLACK...w?reviewflag=1
Riding a blue plated HSUN 200GY (Otherwise know as a ULIKE 200GY, SUNL 200GY or a VIVA SX200S), a 2010 Gio Mini Hummer 110cc ATV, 2010 Gio T3 Rebel ATV, and a 2002 Kawasaki KLR650, 70cc Katera dirtbike, and a 49cc GIO dirtbike...so far!
Old 06-21-2008, 11:01 PM   #40
katoranger's Avatar
I think my action packer is closer in size to the larger one and it doesn't seem to big to me.
Allen
Old 06-22-2008, 12:43 AM   #41
Yes,its late tonight,but I will tomarrow.
Kman
2007 HI-BIRD 250
2007 Vbike V4S 250
Old 06-22-2008, 08:43 AM   #42
Here is how I applied it.I got the brackets at ace hrdwr.They have several different brackets already drilled .
Kman
2007 HI-BIRD 250
2007 Vbike V4S 250
Old 06-22-2008, 11:12 AM   #43
kczukiman - I do like that a little more than the way I have my action packer attached. I need to go to a Ace and see what they have to add to my configuration.
I need this box to be really sturdy because it will carry my computer and stuff on my daily commute. Loosing it mid way will not be nice. $2700.00 to replace my Mac Book Pro...not so good.
Old 06-24-2008, 11:10 PM   #44
Kato and kczukiman - I was wondering how do you lock your trunk? I tried a long shaft mater lock and I could not get it close? I also tried a waterproof master short shaft lock and I could not get it through the hole.
Please do tell...
Thanks.
Old 06-25-2008, 10:06 AM   #45
katoranger's Avatar
I used just a couple old master locks. Tight fit on the hole, but it worked.
You could probably drill the hole slightly bigger.
I don't usually lock it. Nothing of much value in there. I have used them when I left itin a parking lot for an extended period and also for a helmet lock.
Allen
