#31 | |
#32 | |
Straight away I did what you said and it worked perfectly. Stay tuned for more drama from BoatGuy’s “Shade Tree Moto Mechanic Hour”. Live from your local Walmart parking lot. Next Episode: WHY WON’T THIS DAMN TIRE GO ON THE RIM???
2020 Lifan x-pect |
#33 | |
#34 | |
Einstein, Oppenheimer, and I think Feynman or Fermi were in a car on the way to work at the Manhattan Project. They got a flat. Between the three of them, they could not change the tire to continue on to work. I guess somebody saw them and helped them. So don’t get too excited about physicists being really good at fixing machines they didn’t build in the first place. Ha ha ha. Particle accelerators? No problem. Nuclear rectors? No problem. In my own case, plasma sensors and equipment to send telemetry from the plasma readings on NASA SMEX spacecraft back to Earth? No problem. I hear doing these tires might really be tough though. For real. I’m doing them with spoons and hoping to get it right. I have never done this before. But I need to practice in case I blow something on the trail.
2020 Lifan x-pect |
#35 | |
But one thing i do refuse to do is respond on Facebook groups. There a whole different level of stupidity there. There are more people bashing than helping. ![]() ![]()
#36 | |
#37 |
You just learned the most important lesson in valve adjustment. It's not that it has a gap. It's that the gap is supposed to be a certain amount to allow the engine to not only run more efficiently, but also prevent excessive wear. Too large of a gap means the valve tip and rocker arm adjuster slam into one another with a lot more force, causing wear. Too small of a gap and the rocker arm starts putting pressure on the valves when it gets hot, causing the valves to stop sealing, causing power loss and eventually damage and accelerated wear.
#38 | |
#39 | |
#40 |
Hi Tom, the measurement would be wrong. If .002” then it would be to tight right? Hence burnt valves. Again pay attention .002” is incorrect for these valves! So maybe we go to thousands, like .004 intake and .006 exhaust? Or we can do .005 and .007 in thousands not mm. That would be my choice. Thinking out loud!
#41 |
Another thought Tom, you skipped the part about tire pressure?
#42 | |
2020 Lifan x-pect |
#43 |
Do me a favor and read your manual, plus look at your tires. Pay attention to the printed # on on tires. The tires are especially important when it comes to safety! Would you agree? If you don’t want to understand your valves and how they need to be taken care of……great! Again pay attention!!!
#44 | |
CSC TT250 factory recommended lash spec is .07mm. Lifan Xpect factory recommended lash spec is .06mm. Most CG200 and CG250 engines run a lash spec of .05-.08mm as a range. Absolute Maximum is .10mm, but I find this to be excessive. The absolute minimum spec I have seen for the intake valves on a CG250 engine is .03mm The reason they can get away with such small valve lash specs is down to the way the valvetrain is constructed. The cam rides in the lower case, but the followers, which are rocker arms, do not ride directly on top of the cam lobe but on the sides, so as the aluminum cylinder expands and pulls the followers away from the cam it does not affect the valve gap at all. Then the pushrods themselves are aluminum, so they expand at a similar rate to the cylinder and cylinder head, so it minimally effects the valve gap as the engine gets hot. Want to see this in action, install some chromoly pushrods in your engine. You can literally set the lash to zero, and when hot your valve lash will be so large the valvetrain will sound REALLY loud. Aluminum expands faster and greater than steel, so the gap increases a ton as the engine gets hot. If you need further proof, the Honda CG125, the engine all of these clones are based off of, has a valve lash spec of .08mm with a minimum of .06 and max of .10mm. That is why many people run .003" to .004" on these engines, because that is quite literally .08mm to .10mm. I tell you what though. Go ahead and set your valve lash to .008 to .010 inches for me. Record it so I can listen to the sounds of small hammers smashing the valves at a high volume. I'm entertained by strange things like that.
#45 |
It seems like know one is paying attention too the original post!!!!!! Let’s play with the dot and zero. For instance.13 is different than .013…….get it guys… look at the original post!!!!
