Old 05-21-2020, 10:29 PM   #31
simonjester   simonjester is offline
simonjester's Avatar
Originally Posted by legonas View Post
First lets start with powersportsmax, the company i ordered from.
On their website it says, "fully assembled." Is it? Or what is their definition of fully assembled?
2016 CSC TT250
Old 05-21-2020, 11:11 PM   #32
legonas   legonas is offline
you have to install the handlebar, controls on the handlebar, and battery. thats it. install the controls, tighten down the bars, pull the seat to install the battery, check the oil and add gas and you should be on the road. it took me about 2 hours to go from pulling the cardboard off the shipping crate to dropping the bike in my front yard power tools really help taking the crate apart it would have taken forever to do it with just a socket or end wrench.
edit: also thinking about it the front blinker light assembly's also have to be screwed in. the nut and washer is already on the wire just have to tighten it together.
Old 05-22-2020, 09:41 PM   #33
oincman   oincman is offline
Yup and those turn signals are a bitch to tighten down.
Here is what I just got assembled. And yep, the headlight was a bitch as well.
Feels faster than the X-Pect. The test will be the hill I go up on the way to work. Can't get the X-Pect over 62 (according to the speedo, and it drops quickly on the hill).
The KPM is 6-spd and geared different. Definitely pulls much harder than the X-Pect, but I've only ridden it down the road testing my helmet cam.
More to follow......
Old 05-23-2020, 07:41 PM   #34
just got back from the first trip. did about 80 miles of 80% dirt roads. for those interested, we did the SCAR route in the Francis Marion national forest from the rembert c dennis boat landing to the wambaw cycle trail, and then back.
https://www.legonas.net/images/bike2.jpg
learned a lot on my first trip and gained a lot of confidence in my riding. Still have a lot to learn but i dealt with all sorts of conditions and everything went great.
As for the bike itself, i did not tighten the front turn signals enough because they worked loose on the way back so i have to fix that. I had no mechanical problems beyond that. I certainly understand the desire to change the gearing to get a little bit better top end, 55-60 was pushing the bike hard with me on it.
Next project is an oil change, USB charger and LED headlight. I knew that it probably didn't have a oil filter but looking through the manual i don't even see a strainer. Is there a strainer or anything i need to check when i do the oil?
Old 05-24-2020, 07:33 AM   #35
JoshXpect   JoshXpect is offline
There is a strainer low on the right side...I think it was the right, (I'll look when I get home from work) of the engine under one of those silvery plastic screw on caps. There's a spring under the cap holding the strainer in, but it's not too hard to get back in.
Ok, so much for decent memory, it's on the left side way down low, pretty much under the engine. https://imgur.com/a/8yvtttZ
Old 05-31-2020, 12:26 AM   #36
Be careful with the strainer cap when reinstalling. The flange (typically) is very thin and will crack with too much force.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 10-07-2020, 09:21 AM   #37
Jbmoto   Jbmoto is offline
Thumbs Up Got one
This bike is awesome on road not enough power for sandy trails but nobby tires would help better for dirt small fork aren't good for aggressive riders but great road miles im up to 170+ not broken it yet so top speed attempt was 60 mph
File Type: jpg 20201005_162636.jpg (157 Bytes, 795 views)
Old 07-06-2021, 09:58 AM   #38
Cjallen14   Cjallen14 is offline
I just got mine about a week ago. Changed the oil, new spark plug, adjusted brakes, adjusted the valves (make sure you do this!), adjusted chain and a few more things. I set the valves to 03/05. Runs and drives great.
File Type: jpeg 2BAB0809-A0B1-4217-9EFB-57093BC095B8.jpeg (15.3 KB, 163 views)
x-pect
