Old 03-09-2020, 07:52 PM   #31
Chrisguga   Chrisguga is offline
Yeah, this screws my potential first night getting to ride. I don’t want to put gas in it at this point.
Old 03-09-2020, 08:02 PM   #32
Yeah. That kind of puts a damper on it. I'm sure Venom will take care of it.
2004 Honda ST 1300
Old 03-10-2020, 12:12 AM   #33
Current situation. I’ll either get a new tank from Venom or have to figure out how to fix this one. This isn’t how I expected my first “brand new” motorcycle purchase to go.
File Type: jpg 03D0E2F2-21B3-4D4C-9E33-C80FA191F4FC.jpg (20.3 KB, 338 views)
File Type: jpg B914FCC5-100C-4C4C-A42D-4893F0960114.jpg (16.4 KB, 345 views)
Old 03-10-2020, 08:25 AM   #34
Now would be a good time for valve adjustment and oil cooler install. I sure Venom will take care of the tank.
2004 Honda ST 1300
Old 03-10-2020, 08:37 AM   #35
Yes, I’m definitely getting any and all maintenance items completed while I have the plastics and tank off and await a resolution.
I see those caps that have to be removed for the valve adjustment. I bought the feeler gauges, but it looks like I might need the offset ones in order to approach from the top. I’ll know more when I pop those caps off tonight.
Old 03-10-2020, 09:35 AM   #36
I used the regular feeler gauge though the angled ones would work better. It's a good time to do the header wrap too.
2004 Honda ST 1300
Old 03-10-2020, 10:36 AM   #37
Well, Venom tells me this is normal from test firing the motor and the rust is caused by the residual gas left in the tank.
I’m going to use oxacylic acid and water to clear out the rust and then use one of these gas tank coatings like POR15 to coat it before I reinstall it. I’ll have to figure out how to protect the electrical components in the tank during this process.
This is disappointing, but it is what it is.
Old 03-10-2020, 11:04 AM   #38
Hopefully you can clean it out. I would avoid using a tank liner is possible and just clean it with the rust remover. Be ready to use a oil and gas mixture to coat the inside of the tank as soon as you clean it out to prevent flash rust.
Tank liners can fail and cause more issues later on. Tank liners or intended as a last resort for old tanks that have rusted through.
2004 Honda ST 1300
Old 03-10-2020, 11:18 AM   #39
I would use Evapo-Rust Remover so you don't get the flash rust. https://www.amazon.com/Evapo-Rust-Or...dp/B00M0TLQ66/
2004 Honda ST 1300
Old 03-10-2020, 11:22 AM   #40
Man, I need to start listening to my buddy. He gave me the exact same advice on the oil and gas mixture.
Thanks for all of your help, Jerry. I’m still glad I purchased the bike, but was definitely wondering if I should have just financed a new Kawasaki Ninja1000 vs paying cash for this bike when I was out there at 11pm last night cursing the rust.
Old 03-10-2020, 11:38 AM   #41
True story from this past weekend. I have a buddy of mine that's a diehard HD rider told me "why you buy that cheap Chinese junk?" I told him. Didn't you just pay $38,000+ for that bike you just bought? How much did it cost you when you had to take it to shop to get repaired two weeks ago? You could here crickets. It damn near cost him as much as our bikes cost to fix. Then I told him. Yeah my 3 year old $1100 Hawk never left me on the side of the road either. Nuff said.
2004 Honda ST 1300
Old 03-10-2020, 12:36 PM   #42
I went ahead and ordered the oil cooler and set of valve adjustment tools. I hope like hell I like this bike because I sure have spent a lot on maintenance items and accessories. Well, a lot in relation to the cost of the bike.
It’s still exceptionally cheap compared to boating!
Old 03-10-2020, 03:26 PM   #43
Ain't that the truth. lol
2004 Honda ST 1300
Old 03-11-2020, 01:39 AM   #44
So tonight’s progress...
I treated the gas tank with oxacylic acid and water 3 times. This did a nice job of removing the rust. I then swished some 50:1 gas:oil mix that I use in my weed eater and blower to give the tank a light coating of oil. I did this twice and emptied the contents each time.
Here are before and after pics. I used these plugs from a car interior fastener kit to plug the holes in the bottom of the tank.
I had to use the Dremel on some of the plastic to fit one of the mirrors as the plastic was covering the threads. That’s the last pic.
Old 03-11-2020, 01:44 AM   #45
Oh yeah, the plugs. I thought it was a good idea and it worked well.
I also installed my NGK plug and changed the oil tonight. I decided to go ahead and put the plastics back on so I could ride and get 100 miles on it so when I do the valves and oil cooler, I’m ready for my next oil change. Getting the plastics back on is a bit of a pain, but I’ll be faster with it next time.
Here’s how she sits all buttoned back up.
