#31 |
1and 1/4 is too big. Your 'memberin' is just fine. 1and 1/8 will do it
I got alot done today. The mess of wires was gone though. I eliminated the turn signal wireing, and the horn. Took a wild guess at the head light wires, and whent with blue, wich should be the high beam. I accidentally cut the connector off the left switch box, wires were too short, so i had to solder them back together. Spliced in the connector for my grote led headlight. Wrapped it all back up nice and tidy, put the tank back on and the seat. After wards , I turned the key to make sure i still had spark. Yup. Spark. But since im going batteryless, i cant check the head, tail or braek circuit. Cani hook up a 12v7ah battery to the red on the key switch? I cant start it untill i check valves and put the carb back on.
2006 roketa 200cc 1971 Yamaha xs650 2x 1980 xs650, 1 is a café, other is a chopper/brat 1972 Honda xl250 2x early 90's Honda rf600 parts bikes more mc junk laying around. ![]() |
#32 |
I cleaned out the carb, and put it back on. Wondering if the cable is supposed to go under the the back bone or over? Its under right now, and dosnt snap back. Its at quite a dramatic angle coming out of the top of the carb. The cable sheathing is in poor shape.
#33 |
Have you already cleaned and lubed the throttle cable? The cable on our Bashan goes in at a similar angle and it will snap back easily
"Think as you like... but this self proclaimed Professor is always right" - Buckshot ![]() "You never know what someone is hiding beneath their smile..." - NinjaTom - R.I.P. |
#34 |
It's pretty beat. I grab a new one. Thanks
#35 |
How do i drain the fork oil? I don’t see a drain screw. Do i have to take the forks off and turn them up side down?
#36 |
It runs!!
Adjusted the valves. They were tight. Fresh gas, full choke. Started kicking. 20 kicks the n it fired! Snicking thru the carb and worsened as it settled into idle. I had dumped a few shots of seafoam in the crank case . After i go it to high idle, and get hot, i drained the oil again. Was gray. Put in fresh load of 15-40 deisel oil. Fired it up. Puked oil alover. Drained excess out. And started fiddling withe carb. I have the idle mix screw 1 and 3/4 out(pz27). .”snickicking “ subsided but wont let it idle without choke. I set the float with the seam on the float parallel to the gasket flange, but i have gas weeping from the bowl seam. Did i set it to high?
In any case. I heard it run . Sounds strong, no wierd noises from the motor itself.
#37 |
There should be a drain screw on the bottom of the forks. Take them off and turn them over to drain would be the best way.
#38 |
To be fair, the bolt at the bottom isn't really a drain screw. It's the retaining bolt for the dampening rod. The easiest and least frustrating way is to remove the top fork cap and invert the forks.
Basic How-to. 1. Lift the bike in the air so that the front wheel is off the ground - many methods to do this. 2. Remove the front wheel. 3. Loosen the top clamp bolts on each side. (steps 2 and 3 can be interchanged) 4. Break the fork caps free (hex bolt shaped item on the top) but do not remove them. Just make them loose. 5. Loosen the lower fork clamp bolts. While looseing these, have one hand on the fork leg just in case it decides to slide out on its own. 6. Remove the fork. 7. Using a wrench/socket, and a rag over the top cap, loosen the cap carefully until it comes free. 8. Remove the fork spring and preload spacer - careful not to lose these. 9. Invert the fork into a container or drain pan. Once most of the oil as run out, pump the fork in and out a few times and this will help remove more oil. Once I do that, I sometimes leave them upside down to help drain as much as possible. I will do one, leave it upside down, grab the other and start working on it. 10. Fill each fork leg with the recommended level of fork oil. Cycle the fork a few times to help purge them of any air. I recommend taking the time to measure the air gap of the fluid to the top of the fork tube with the fork fully compressed. This will allow you much quicker/easier fluid changes in the future, and also allow you to even the levels if one or the other happens to be off. I use a metric ruler for this, but even a measuring tape can be used. Obviously you don't HAVE to do this, but it can be handy. 11. Install spring and then preload spacer. Then install cap and tighten it down as much as you can manage. 12. Reverse the removal process. Before you tigthen the top clamps, give the fork caps a good snug up. You don't need a ton of force on them, just a little extra to ensure they are tightened down. Do NOT lean into these, or feel the need to crank on them hard as you will strip the threads if you do. At this point you are done.
#39 |
Thanks dan. Im trying to upload a first start vid, but takes too long. It times out. Photo bucket really put a hurt on the internet. Im trying to use my phone to do it.
I need to pull the front end apart and see if the steering head bearings can be saved. I have no idea how long it’s been slopping around the way it is.
#40 |
Personally, I would just replace those head stock bearings. It doesn't take much of the wrong kind of pressure to cause a small amount of damage that will grow over time. For less than $40 you can have both converted over to taper roller bearings, which are simply better. Plus you can have peace of mind.
Just my 2 cents, so take it that way.
#41 |
Thats what I’d like to do, but having trouble finding the right ones. Tive done 4 conversions to different bikes and it has alway improved stability
#42 | |
#43 |
Do you think bearings for a honda xr would be right? That’s pretty much what this bike is.
#44 | |
Likely they are the same XR bearings that most of these bikes seem to use, as it is a common bearing for many Honda dirt bikes, but I would hate to say "yes" and it turns out to be some other bearing size.
#45 |
Megadan would know more about this than I do. I seem to recall the the headstock has to be re-machined deeper in order to accept the tapered roller bearing. Perhaps he would be kind enough to address this question....ARH
