12-22-2016, 01:02 PM | #31 | |
I'll probably set the 2 ATV's up differently and see what we like about each setup. I haven't completely un-crated the 2nd one, but so far the only difference I see is one has all disc brakes and the other has the drum brakes. If everything goes well, we plan on getting another pair of these in 3 or 4 months for my wife and I. |
12-22-2016, 08:01 PM | #32 | |
A Christmas Story 2016
HO HO HO !
12-23-2016, 12:07 AM | #33 | |
I got the 2nd one put together tonight. It is a DX2 model. The only real difference between the two that I can tell is the battery and the front brakes. The rear tires are different and the handlebar mounting bracket is different also, but negligibly so. The second one only took 2.5 hours to uncrate and assemble. And the same number of nuts and bolts left over too. |
12-26-2016, 01:34 AM | #34 |
I picked up a pair myself for the holidays. One is fully assembled (minus hand guards ... how do the inside points attach exactly ?).
I found it surprising how you mostly have to guess what size bolts go where, and when you need to use washers etc. The instructions were little more than the recommended order to put it together, and provided almost no help. Has anyone found good detailed assembly instructions anywhere? I dug for videos and sites and came up with nothing specific. I got it mostly worked out at this point, but would love to double check my work. Ty. |
12-26-2016, 09:56 AM | #35 | |
12-27-2016, 11:48 AM | #36 |
This might help for hand guard mount. Clamps mount right under the cross bar on the handle bar.
12-27-2016, 03:38 PM | #37 |
Snazzy! On the red clamp holding your handlebars, is that the R and N indicator lights? Both of mine have them on the left fender.
12-27-2016, 04:06 PM | #38 |
That is correct sir. Aluminum fuel cap too.
