#31 |
Ooooooooooooooooooooooooooo..............SHINY!
Hate to tell you but you aren't sleeping tonight. ;-)
#32 | |
#33 |
GOOD GARDEN PEAS!! This is harder than I thought.
#34 |
congratulations, it looks great. Can't wait to see it all together.
#35 | |
#36 |
And from the spoke trouble guy...use the spokewrench
![]() As they say, Heyman, nice bike! Tires come and go quick so you can put on what ever you desire in the future, especially if you will be doing lots of fieldwork. Blue Threadlocker. Main tighten points for sure, break caliper, shifter, steering coller nut, kickstand nut, clutch tension,...and everything else, then do it again. Easy does it with the brittle plastics. Get some kind of lube or oil in the cables too first thing, you know what to do with the engine fish oil (no Saturday night stir fry). nǐ hǎo ...yall
#37 |
can someone tell me what these are?
#38 |
looks like something to hold your plastic on?
#40 |
Yes, I remember it goes 'down the middle' under the tank, and you bolt the tank plastics to it on either end (it has been a few years since putting my TMEC together so I don't remember exactly how it bolts on)
#41 |
The one on the left is a mystery to me. Like hertz9753 mentioned, the one on the right, you bolt on the plastics that are associated with the tank. It goes under the tank, across. I remember having one of those on my TMEC 200 for the tank plastics.
The one on the left looks like it is for plastics, too, but not sure where it goes since I did not have anything like that on my TMEC.
#42 |
Thanks guys. That is exactly what they are. The two on the left are the front fender support. And the one on the right is the lower Tank shroud support. Sadly I must quit with her today. I have to get ready for date night. But check this out. This bike has a real Keihin Carb and an NGK spark plug from the factory
#43 |
Oh yeah, and can someone tell me how to get the seat off the thing?
#44 |
Thank you Jeffrey!
#45 | |
