11-07-2016, 08:32 AM | #31 |
That should work.
11-07-2016, 08:39 AM | #32 |
I'll have to take mine off one weekend and see how bad it is. I'm an old guy and don't like the loud exhaust like I use to lol. But there may be a few things I could do to make it flow better and still keep the exhaust quiet down enough.
11-07-2016, 10:10 AM | #33 |
Before you take the exhaust pipe (head pipe) off, I would suggest you get a copper o-ring exhaust gasket for a Honda CRF-230. Then re-torque the exhaust to head bolts, step by step to 15 ft/pds (with the copper o-ring gasket). After you have the head pipe mounted, then re-mount the muffler.
11-07-2016, 11:01 AM | #34 | |
11-07-2016, 12:01 PM | #35 |
I think a pair of these LEDs mounted vertical should fit where the reflectors are up front. https://www.amazon.com/autvivid-Driv...cm_wl_huc_item I'll take some measurements tonight.
Update: I measured up everything and it looks like they will fit. It might be close to hitting the plastic on the tank but I think I can make a bracket to offset for clearance. If you never been off-road trail in the woods at night you are missing a great experience. Ran across a couple of deer this pass weekend. I really need to invest in a helmet cam for the next time I go.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-08-2016 at 03:35 PM. Reason: Update |
11-08-2016, 09:47 AM | #36 |
There are sprocket combinations that should be avoided, I found a chart somewhere a while back when I was changing my Duc's gearing. I believe the reason was a combination of vibration and wear do to an interaction between the sprockets and chain, but don't recall the details. It may not be a big deal on a low power/low speed machine, but if your desired gearing can be had with a better combination of sprockets it would be the better way to go. I think I wound up running one of the 'wrong' combos on one of my 999s and didn't notice anything wierd but I didn't ride either one a lot to really know, I also did a few swaps trying to find the best gearing & chain size and don't recall what combo either one ended up with. I did a 525 to 520 conversion on one of them and the reduced weight could be felt in the acceleration. Getting the lightest combination on a CB should help it too, but of course smaller lighter parts that are strong are usually more $.
11-08-2016, 03:13 PM | #37 | |
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-14-2016 at 05:24 PM. Reason: more information |
11-21-2016, 10:23 PM | #38 | |
As for the sprockets, what is your top speed with the new combo? |
11-21-2016, 10:30 PM | #39 | |
11-22-2016, 01:44 AM | #40 | |
If we rode own bikes in a totaly sterile room it could have a bearing on chain / sprocket life.. But I ride mine in the real world with water / mud / dust & the chain totaly dry after 10 mins riding.. Wheather the sprockets can be devided into each other or not has diddy squart to do with chain / sprocket life in the real world.. ....
11-22-2016, 06:33 AM | #42 | |
My first trip out I clock it at 74 on my GPS. I took it out Sunday and got up to 72 before I backed off the throttle.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-22-2016 at 07:36 AM. |
11-22-2016, 06:42 AM | #43 | |
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-22-2016 at 09:56 AM. |
11-22-2016, 08:00 AM | #44 |
This also could works the opposite way. If you had a link or two that got damaged and stretched it will wear on the sprockets at the same teeth. I can see this happening more than a tooth getting bent or damaged. My stock chain is about shot already so on my next order I'm ordering an o-ring chain along with the LED lights and Hand brush guards. My last off road trip I bent the Clutch lever and busted the crap out of my hand. Lucky I had some good hard knuckle tactical gloves that cushioned the blow.
11-22-2016, 09:45 AM | #45 |
You've got it backwards. The "hunting tooth" system evens the wear around both sprockets, and the chain, if it is done as described.
