#31 |
I got these and they're damn bright. Mounted them on the front plastic guard. I wired them into the high beam circuit.
https://www.amazon.com/Nilight-Drivi...led+atv+lights I also mounted some similar, but round units under the rear rack for reverse lights
"Light a fire for a man, and you heat him for a day. Light a man on fire, and you heat him for the rest of his life." 2007 Suzuki DRZ400S (SM convert) 2009 Q Link XP 200 1967 BSA B25 250cc Starfire 2022 Royal Enfield Interceptor 650 2023 Royal Enfield Scram 411 1948 Royal Enfield Model G 350 Last edited by 2LZ; 02-06-2019 at 10:18 AM. |
#32 |
Sorry, double post.
#33 | |
I did however discover that if you back out of the garage fast, then instead of using the brake, you click it into first and use the clutch as your brake before you start rolling forward, it will torque down on the chain roller and pop the chain off. 2LZ usually learns the hard way.
#34 | |
Had a pair of Rigid D2 driving lights that I pulled off our truck before we sold it(too $$$$ for this ATV). Sold them to a friend that lives in Napa, CA for a 6 wheeler of his. Even the so called high beams don't light squat up. |
#35 |
Couple questions..1. Is this the right plug for this motor-NGK D8EA. 2 is it ok to run Rotella T6 5w-40 in these or should I stick with the heavier oil for the clutches?
Thanks! |
#37 |
Like mudflap said you have the right plug. Our Rhinos are manual gear boxes so you do not have to worry about oil for the clutches. A manual system is dry only the autos have that setup.
#38 |
Lights similar to what 2LZ put on his. Had a slight hip issue yesterday which kept me from installing. Plan on sharing when I can get to them.
1986 TT350, 2002 Grizzly 660, 2009 TR125 and two 2015 Kandi 150cc Quads. |
#39 |
Just to be clear, CG engines like most motorcycle engines have a wet clutch so the type of oil does matter. Rotella oil for diesel engines and most motorcycle specific oils are fine but many car oils will cause the clutch to slip.
#40 |
Got tired of the no low end grunt and the excessive chain noise from being sloppy. So spent the coin on one of them WGS 37 tooth rear sprocket. Wasn't really knowing when to expect it. So got it ready for it. I knew the jets were coming today but..
#41 |
I also seen that they didn't use sealed bearings in the rear carrier so took the needle tip and squirted some marine bearing grease down in there on both sides. Found a couple spare metric bolts from the kids Coolster ATV's and used them on the sprocket ring, since they were missing the threads in the middle which was weird!?!
#42 |
axle aligment
You say you can not align the rear axle???? I always loosen off the bolts and the adjustors( make sure the jam nuts on the inside are removed so yu can adjust the turn buckle)... and use a 1 inch ratchet strap to pull the axle if it needs to be moved forward.. this will cause the axle to straighten out... just use the adjust on the chain side to tighten it up.... this is the same setup on the 125 F1 and the 150 d and RHINO models..
the rear axle can be aligned this way... same method for the small ones... Both axle spread distance should be no more than 1/2 inch difference... with about 1/2 deflection in the chain.... works for me and all my customers once they remove the back inside lock nuts so they can adjust the chain tension with out stripping the thread as many do not LOOSEN the locking bolts on the rear axle
#43 | |
#44 | |
#45 | |
http://www.whygostock.com/taotao-rhi...ooth-sprocket/ |
