Old 07-19-2016, 10:33 AM   #31
Originally Posted by Azhule View Post
Check out this on the Watt-Man website, people are doing similar things to their KLR 650s... I'm sure grease fittings can get put on our China Bikes also
http://www.watt-man.com/uploads/ZerkInstallation.pdf
That looks like a great idea! I was thinking of a zerk in the middle of the swingarm. My mistake.....
Old 07-19-2016, 11:25 AM   #32
This thread brings me so much joy!
Old 07-19-2016, 12:49 PM   #33
kohburn   kohburn is offline
kohburn's Avatar
Then, this morning I woke up thinking it would be a great disservice to our humble community here if I didn't attempt to repair the "leaky adjuster screw" some of us have. My right one has been weeping. I'll be looking at that tonight to see what I can see.
I've got one dismantled at home
CSC sent me a replacement cap to install so after I did that I dismantled the original one to find the o-ring with a section that was pinched off during the installation. I plan to rebuild it with a new better o-ring to keep as a spare.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 07-19-2016, 01:03 PM   #34
Awesome news! A screwed up o-ring was what I was hoping to find. I'm glad though that CSC backed you up with a new part. Great service.
I have a ton of O-rings so I'm hoping I have the right one in stock....
Old 07-19-2016, 01:05 PM   #35
kohburn's Avatar
I'm 90% sure I have the right size in a basic butyl rubber o-ring, but I'd like to replace it with something a little more robust and less prone to pinching.
- 2016 CSC TT250
Old 07-19-2016, 01:07 PM   #36
.....something a little more robust and less prone to pinching.
That sounds like all the qualities of a really good beer! ;-)
Old 07-19-2016, 01:17 PM   #37
oddthought   oddthought is offline
oddthought's Avatar
Whaddaya know, I've thought the same thing about one or two of my kids!
Previous: '80 KZ550, '04 Shadow 750, '12 NC700X
Current: CSC TT250
Old 07-20-2016, 09:57 AM   #38
Forks
Good morning fellow China Riders.
As kohburn and I discussed yesterday, I decided to open up the right fork and go in after that o-ring. All was going well and I was taking pics as I was moving along....until I got the cap off, the fat rubber washer removed and placed it in the vise. BTW, the cap is held in place by the usual double-nut setup.
On a side note, it is kinda cool how that little screw/rod works, once I got it in my sights (see pic on workbench with needed supplies on hand). I can tell you that the little screw head is "in place" in the cap and the rod threads into it, via a slot and flat blade type of joint. The tricky part is when you're screwing that rod back into the cap....to line up the blade with the slot and finish threading it in. If the screw isn't turning as you turn the rod, they aren't mated together. Keep that in mind.
As you can see, the inner piece of that cap has been thread locked with something akin to red locktite. I had a long wrench on it trying to coerce it back and forth but to no avail. I didn't want to destroy it or spin off the aluminum head of the thing. I was aware that something like this may occur from a post I had read on advrider but I was hoping for a work-around.
In the meantime, I've emailed Ryan with a pic and am hoping for a warranty replacement for it....before I take a torch to this one and try to bust it lose. We'll see. I just didn't want to go after this with a torch yet until I had a backup.
Old 07-20-2016, 10:10 AM   #39
Carbs
Not like dual carbs...(yet)...but like the Mikuni vs the Keihin clone PZ.
I got the Mikuni last night and already had the jets on hand from Jets-R-Us (they always ship to me blisteringly fast).
I unboxed the Mikuni and it was the usual, nicely done carb that I've received in the past. I installed the jetting I'm starting with (25/110) and set the screw at an even two turns out just for reference....then mounted it on the TT.
I don't have comparison pics because..well..I blew it....but I have to give another "hats off" to Zongshen for the PZ carb they are using on the TT250. Compared to the POS sealed up PZ that came on my Rhino (it looked like a sandcasting from a 5 year old, gone bad), this PZ carb seems a really nice piece. So....that being said, unless you want all matching carbs on your Hondoids for jet swapping...and especially if you do the cheap PZ rebuild kit that has the real mixture screw like rojo linked for us....I really don't see any reason to spend the 30.00 to swap it out, if you have the right jetting for your mods/elevation. Really.
I'm going to keep the PZ as a backup and stuff one of those rebuild kits with the screw in it.
Old 07-20-2016, 10:42 AM   #40
SeerAtlas   SeerAtlas is offline
Grin
[Q UOTE=kohburn;225436]I'm 90% sure I have the right size in a basic butyl rubber o-ring, but I'd like to replace it with something a little more robust and less prone to pinching.[/QUOTE]
sounds like a friend's critique of the population in the Florida Keys, specifically Key West!
(for you straight east coast and midwest types, think Province Town Mass or San Francisco
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking
Old 07-20-2016, 10:48 AM   #41
ughmas   ughmas is offline
ughmas's Avatar
Nice work 2LZ, hopefully they will replace it for you. I had a slight drop of oil on the top of my right fork when I first got it, however after I wiped it off I have not seen any oil come out since. Hoping mine hold up OK.
2005 CBR600RR
2016 CSC TT250 Coming Soon
Old 07-20-2016, 10:48 AM   #42
pcspecialist   pcspecialist is offline
why the inline filter? Did you remove the filter in the gas tank?
Old 07-20-2016, 10:52 AM   #43
Crying
Well I seem to have dodged the weeping o'ring problem on my tt250, but alas, something seems to be wrong deeper inside my front forks, almost feels/sounds like something has gone adrift in there..:( Hopefully its something simple but i'm afraid 'hope' in this case may be unrequited :(
Old 07-20-2016, 10:54 AM   #44
The bike came with an inline filter....that broke apart and leaked with about 10 miles on it. I just replaced it and the cheap fuel line with "known good" since I had to remove it.
Did not remove the tank filter.
Old 07-20-2016, 11:10 AM   #45
Thumbs Down
my inline filter was NOT completely set/secured into the gas lines on both ends- came loose the first curb I climbed getting into a driveway. fortunately for me, the engine was not yet fully hot, and the gas managed to miss anything electrically live. :(
anyway, something that bares inspection immediately upon un-crating your bikes.
