Old 07-13-2016, 01:02 AM   #31
jet321   jet321 is offline
What's the license plate bulb ID?
Old 07-13-2016, 04:34 AM   #32
Bashan is t10 , larger than the dash bulb size of t5
Old 07-13-2016, 10:30 PM   #33
So I got the bike back together, haven't touched the valves or the carb. It runs great with the new exhaust. I am really impressed what a difference that mikuni and exhaust made to the bike, it makes cracks and burbles now.
So I got my sprockets 16/44T with a 130 link chain. I have to take 5 links off correct? +1 front, -6 rear to make 5. Thanks guys.
The bike is really turning out nice. Will post pics of it finished next week when I have everything on it.
Old 07-14-2016, 07:25 AM   #34
SeerAtlas   SeerAtlas is offline
Thumbs Up
NO!!!! measure first. on my hawks went to 16/45 took out 2 links fit perfectly. measure, measure,measure before you cut! also position rear wheel about middle of adjustment range before you measure to leave yourself some wiggleroom
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking
Old 07-14-2016, 06:30 PM   #35
Gotcha Boss, will do tonight! Thanks for the reply!
Also ordered my Tach cluster from Matt, he still has some if anyone still is wanting one. Cheers m80's
Old 07-15-2016, 08:32 PM   #36
Going to do the valve adjustment this weekend and tune the carb. She's sputtering at 3/4-WOT or at the top of the rev range, seems like a lack of fuel. I think it needs a bigger main jet and the jet needle needs to be shimmed up. Let me know your thoughts. I'm at 3,600 FT above sea level. It is a mikuni 30mm. Thanks guys.
Old 07-15-2016, 10:38 PM   #37
w0ss   w0ss is offline
Do you have the stock jets in the mikuni? Not sure at 3600FT but I would assume it is running lean.
Hawk 250 with following performance mods: 17t, Mikuni with 110/25, Uni filter, Exhaust.
Old 07-16-2016, 07:52 AM   #38
take a few minutes and pull the spark plug for a looksee at the color..darker= richer, your are looking for a light tan color.
Old 07-16-2016, 12:08 PM   #39
It's running stock jets. It runs well at 0-1/2 throttle. But past that, it's running lean for sure.
Old 07-16-2016, 12:32 PM   #40
Ariel Red Hunter's Avatar
That carburetor comes with a 100 or 105 main jet. You may want a 115 main, and a 20 or 25 pilot. If the main is way too lean, the needle can't compensate for it. That is why it doesn't run well to 3/4 throttle. Raising the needle will help some until you can get a new main jet. But it is not a permanent fix.
Old 07-17-2016, 12:47 AM   #41
I picked up a 115 and it was running way too rich. I'm going to try a 105 or a 110. I also shimmed up the needle and it may have been to much. I'll keep tinkering with it.
Old 07-17-2016, 01:45 AM   #42
pcspecialist   pcspecialist is offline
You shimmed up the needle? I thought you said you got a Mikuni? If you are using the stock carb, 110 is big enough even at sea level. A Mikuni needs a 115 at sea level.
Old 07-17-2016, 02:01 AM   #43
hertz9753's Avatar
Maybe he just moved the needle up with the clip.
Old 07-17-2016, 11:48 AM   #44
Yeah I shimmed the jet needle up with a washer. The 115 seemed to be to much. It was choking on fuel. I'm out of town but I'm going to keep trying to play with it when I get back. Also what's the marking for dead top center for the motor, I need to do the valve adjustment.
Old 07-17-2016, 01:47 PM   #45
It will be a line with a T next to it.
