Old 04-11-2016, 05:09 PM   #31
Ron B   Ron B is offline
Ron B's Avatar
This is sad, don't even have my bike yet and went ahead and picked the bearings up today while at work. At least I'll have them....
Wingless Hawk, 2016 orange RX3, 97 wide glide,2003 KLR
Old 04-11-2016, 05:36 PM   #32
dpl096   dpl096 is offline
dpl096's Avatar
Bearngs
Wonder if the TT uses the same bearings........
Old 04-11-2016, 07:15 PM   #33
traygiddens   traygiddens is offline
Everytime I log in, I see a new " oh crap , i better check that thing" post.
but seriously , i'm have a fun time putzing around on my little hawk. The mikuni was a big improvement on several fronts.
Old 04-11-2016, 09:51 PM   #34
Originally Posted by Eco Mouse View Post
Do you have a link where I can buy the higher quality Japanese bearings?
I bought mine years ago from Bearing Resource, but I don't think they are selling online any more. Check the following thread.
http://www.chinariders.net/showthread.php?t=5243
Old 04-12-2016, 12:54 AM   #35
Eco Mouse   Eco Mouse is offline
Eco Mouse's Avatar
I found NACHI brand Japanese bearings on Amazon, in the sizes you listed. They were about $7 each, as opposed to $1 - $3 for the other brands.
What is the size for the front wheel? I'll just make a go of it, and buy all 5 right now.
Old 04-12-2016, 12:59 AM   #36
The front wheel employs two, 6302 2RS bearings.
Old 04-12-2016, 01:04 AM   #37
Post Edited to Correct Errors
CSC, Cyclone RX3 motorcycles sold in the United States contain the following bearings.
Rear Hub Bearing Sizes
Rear Hub Bearing, Sprocket Side: Two 6202 2RS Bearings
Rear Hub Bearing, Brake Rotor Side: Two 6302 2RS Bearings
Sprocket Carrier Bearing: 6004 2RS
Forum members living in foreign countries might have an earlier version of the rear hub. It contains the following bearings.
Rear Hub Bearing, Sprocket Side: 6202 2RS
Rear Hub Bearing, Brake Rotor Side: 6302 2RS
Old 04-12-2016, 01:14 AM   #38
Eco Mouse's Avatar
5 bearings totaled $22! For piece of mind, sounds good to me!
If I recall correctly, bearings were the only issue with some guy riding through Europe, right?
Old 04-12-2016, 02:35 AM   #39
I think the Silk Road Rider only had problems with his rear wheel, and I wouldn't be surprised if it was only the 6202 bearing causing the problem.
The 6302 bearings are large and robust. The 6004 bearing is serving light duty in the sprocket carrier. As long as these bearings are packed with sufficient grease, I don't think they will cause any problems. However, I received a replacement rear hub from CSC which only had two bearings. I suspect the Silk Road Rider had the same hub, and the weak spot is the single, 6202 bearing in the rear hub. RX3 bikes sold in North America have an upgraded rear hub which contains four bearings, instead of two.
Old 04-12-2016, 10:05 AM   #40
jbfla   jbfla is offline
The 6303 bearings are large and robust.......
In post 37 you posted the bearing # as 6203. Is one a typo?
Can the bearings be re-greased in place (without removing them from the wheel)?
2014 XT 250........
Old 04-12-2016, 10:36 AM   #41
Originally Posted by jbfla View Post
In post 37 you posted the bearing # as 6203. Is one a typo?...
I made a typographical error in post #39, and I have corrected it. Thanks for letting me know.
Except for the 6004 bearing, all the other bearing numbers end in 02, which indicates an inside diameter of 15 millimeters, the diameter of the axle.
The 6004 bearing of the sprocket carrier has an inside diameter of 20 millimeters, since it contains a bushing which has that outside diameter.
Old 04-12-2016, 10:45 AM   #42
...Can the bearings be re-greased in place (without removing them from the wheel)?
Give it a try; you might be able to do it. You have nothing to lose by trying.
Old 04-12-2016, 11:07 AM   #43
Here is a photograph of the SKF 6202 2RS bearing I installed in the sprocket side of the rear hub. Since I have an earlier version of the rear hub, I only installed one of these bearings. The bearings in the brake rotor side of the hub are 6302 2RS bearing.
I used the orange pick to pry open the rubber seals from the inside diameter of the bearing. I packed the bearings with Lucas Red "N" Tacky #2 grease. The photo also shows my 15 mm split collet, and the large driver I used to drive the old bearings from the hub.
Old 04-12-2016, 11:11 AM   #44
Here is a photograph of the worn original bearings I removed from the rear hub. The 6302 bearing on the left was missing one of the rubber seals. This bearing was locked and dry.
The 6202 bearing on the right was completely shattered. I needed to cut the outer race with my dremel tool in order to remove it from the hub.
Old 04-12-2016, 11:39 AM   #45
rtking   rtking is offline
Wow - those are some dramatic photos. Given that, spending $22 for a set of spare bearings for peace of mind is cheap insurance.
