Old 01-29-2016, 12:56 AM   #31
The CSC tutorial for the center stand installation is located at the following link.
http://www.cscmotorcycles.com/Articles.asp?ID=288
Old 01-29-2016, 01:00 AM   #32
I have added this thread to the RX3 Tech Sticky, under the Modifications subheading.
http://www.chinariders.net/showthread.php?t=14228
Old 01-29-2016, 01:18 AM   #33
rjmorel   rjmorel is offline
rjmorel's Avatar
Great pics and write up on your install Spud. Only comment I have is in painting your grinded area. It may be a wash as that area gets blasted by the front wheel with rocks and stuff. Mine looked pretty unpainted in that area from all the gravel roads I rode this summer. rj
Live Zong, and Prosper
Old 01-29-2016, 01:21 AM   #34
Thanks for the tip and the kind words, Rob.
Old 01-29-2016, 08:44 AM   #35
Inroads   Inroads is offline
My original Centerstand lofts the front wheel even when my side and top boxes are empty.
Nice to hear that the new one lifts the rear wheel.I'm curious how that is
Re-design or because no boxes on Spud's bike ?
Old 01-29-2016, 10:09 AM   #36
When it is convenient, I will remove the center stand and weld a gusset between the deployment arm and the left leg of the center stand.
You have my full attention. Did you buy an Eastwood?
Old 01-29-2016, 10:36 AM   #37
woodlandsprite's Avatar
I suspect it might be due to no boxes on spuds bike.
I had one of the side boxes off of my bike when I did the valve work - and if I remember right, it was much happier to loft the rear wheel then.
What I'm curious about is the contact with the frame requiring that the top of the stand be ground down - especially if the design is such that the existing stands were unchanged and an arm was simply added. i do not recall having such an issue with my center stand.
Old 01-29-2016, 11:11 AM   #38
I had one of the side boxes off of my bike when I did the valve work - and if I remember right, it was much happier to loft the rear wheel then...
I have all the standard equipment, including both panniers, installed on my bike. However, I did remove the stock trunk, and installed a Garage Pro Travel Trunk. The travel trunk was removed when I installed my center stand. The 2nd generation, center stand solidly lofts the rear wheel with the panniers installed. After talking with Ryan, I believe the new center stand might have been modified to loft the rear wheel.
I will install my empty, Garage Pro Travel Trunk this afternoon, and see if the center stand still lofts the rear wheel.
Old 01-29-2016, 11:12 AM   #39
I did not buy the welder, yet. However, I am definitely going to buy the Eastwood welder you recommended.
Old 01-29-2016, 11:21 AM   #40
...What I'm curious about is the contact with the frame requiring that the top of the stand be ground down - especially if the design is such that the existing stands were unchanged and an arm was simply added. i do not recall having such an issue with my center stand.
We must remember, the RX3 was not originally designed to accommodate a center stand. The center stand mounts were originally intended only to aid assembly at the factory. CSC told Zongshen to keep the mounts, and reinforce them, so we could install a permanent center stand. Therefore, the frame clearance with the center stand might be a little tighter on some RX3 bikes than others. In any event, if necessary, it only requires a little trimming with an angle grinder to fix the problem. This 2nd generation, center stand is very nice, and I would not be concerned about doing a little grinding to make it fit. One will do less grinding to install this center stand than he would to install the CSC skid plate.
Old 01-29-2016, 01:02 PM   #41
I remember having to grind down either side of my center stand to fit between the mounts.
Based on your high praise and recommendation, it looks like prehaps I should contact CSC about that new center stand!
Old 01-29-2016, 05:29 PM   #42
GSC   GSC is offline
Spud . Most photos I can get, not yours though.' Webpage Unavailable'. My old computer might be due for a change?
I will install my newly arrived centerstand next week. Thanks as always for your thorough posts.
Old 01-29-2016, 05:54 PM   #43
You're welcome. You should be able to view my photos; you might be having a problem with either your web browser, or your computer.
Old 01-29-2016, 09:18 PM   #44
My photos are posted at Photobucket.com, and they seem to be down for maintenance. I think that is your problem, because I currently can't see my photos either.
Old 01-30-2016, 02:20 PM   #45
GSC   GSC is offline
OK that might explain it. I just checked , their up now. thanks
