Old 09-05-2016, 01:18 PM   #31
Juanro   Juanro is offline
Juanro's Avatar
"Noisy" clutch basket seems to be a common issue; I checked mine, and it wasn't really loose, but I re-torqued it anyway (and the nut at the crankshaft end, just in case)
This guy, whom I met personally a week before this incident, reported that he found two plastic teeth in the oil pan after the scheduled oil change. Bike is low milleage (a couple thousand Km). He stopped using the bike, open it, and found the gears like that. After changing them, engine is running fine, and he reported a change in engine sound, more full, less "clunky". That's all I know.
Old 11-09-2020, 04:01 PM   #32
Bertolazzi   Bertolazzi is offline
Hi
I need help
I drained all the oil opening the filter and the 3 plugs to drain the oil. I cleaned everything, put the filters and closed all the plugs. I put 1.7 liters of oil through the main orifice and nothing appeared on the display on the right side ... Even after starting the bike, etc ... What can happen? Thanks.
