Old 08-20-2017, 09:40 PM   #31
i think the heavy duty ones are 4 mm
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 08-20-2017, 10:37 PM   #32
Depends a bit on the brand, but usually. Some heavy duty tubes are 4mm
Old 08-20-2017, 10:39 PM   #33
humanbeing's Avatar
Pls pic the f***ed tube. I want to find out who's the maker by official trademark record http://wsjs.saic.gov.cn/
Old 07-05-2018, 07:13 PM   #34
davidjv   davidjv is offline
Originally Posted by jaymalmat View Post
X2. I have recently bought and installed the Kenda k761 on my Hawk as well. Price was good and performance good as well. Although when delivered one sticker on each tire said tubless and other tube type, they install n run just fine. Loose dirt and wet grass is like riding on a slick but great for road riding.
Hi,
I note the Kenda K761s are slightly wider than the originals (10mm or slightly over 1/3 of an inch) but it seems they are working fine out there with the Hawk 250s?
-Kenda Back: 120/80-18
-Original Back: 110/100-18
-Kenda Front: 90/90-21
-Original Front: 80/100-21
The clearance up front (shocks) and back (chain) seems so tight as it is. Are there success stories out there with the K761?
Old 07-05-2018, 11:21 PM   #35
roundhouse   roundhouse is offline
roundhouse's Avatar
I have the 705s on my bike and love them. they handle SO much better on the street.
http://chinariders.net/showthread.php?t=21276
Old 07-06-2018, 01:10 AM   #36
Yep the 705's are great for bikes that mainly see the road.
If you never plan on leaving pavement at all, then you can go one step better and put actual road tires on your bike.
As far as size and fitment. 120/80-18 and 90/90-21 are the exact sizes I ran on my 705's and I had no fitment issues at all. Plenty of room. If you want to stay true to the rear tire diameter, then a 120/90-18 is almost the same exact diameter as a 110/100-18. 120/80-18 works just fine, but the decrease in diameter is effectively the same as going up 1 or 2 teeth on the rear sprocket, so you may need to adjust for the size difference.
250cc, hawk, tire size, tires
