#31 | |
2016 Versys 650 LT, 2015 RX3 Red, 2011 Ural GearUp, |
#32 |
Yes, the OP has an RX3 with a carburetor.
#33 | |
#34 |
Banned
3.2 x 60 is 192.
So.....looking for fuel just under 200 miles for me. JUST a tad better than the SV's range at it's far side, which I know intimately. So I guess I can live with that. And.....if you have no problem farkling the hell out of a $3500 bike, a Rotopax and mount looks to me to mount perfectly on the rear of the stock luggage. IIRC there was a large group tour somewhere (not US) and the RX3's on it had dual 1 gal Rotopax on the rear of the stock bags. In fact now that my mind is on it, I'd rather spend a shit ton modifying a sub 4K bike than a full tilt GS1345Wc Beemer or Katoom1446v4 adventure. Makes more fiscal and perpetual sense. |
#35 | |
#36 | |
Using mine for mostly commuting (50/50 freeway & surface street) I've conditioned myself to ignore the blinking fuel bar and dim flashy thing and just use my trip meter. 180-210 miles and I put 3-ish gallons in. Stock 14-44 gears & tires. |
#37 | |
Fuel Tank Capacity
I confirmed his comment this past week, the hard way. I had figured that with a 4.2 gallon tank and 60+ mpg on the first two tanks of fuel that I could get 240+ miles on the tank. So I was scheduled to pull into my local station that sells E0 at 220 miles. Well, at 205 miles the engine started missing, and at 206 it was done. After an aborted attempt to get fuel from AAA - they sent the guy to the wrong county - I was able to get ahold of my wife. I asked her to bring me exactly one gallon, which she was able to do. More good news - the bike started up right away. It stumbled a bit the first few miles and then ran normal. After 14.6 miles I was at my E0 gas station and filled up with 2.815 gallons. That works out to 55.6 mpg. I realized that I was probably easier on the throttle during early break-in, and more aggressive now. Figuring in the fuel I burned getting to the gas station it works out to a 3.6 gallon tank - with (important) the way I fill it. There is a tube in the filler neck; I usually fill such that the fuel is about one half inch below the bottom edge of the tube. (Next time I fill I will try to see how much more it takes to fill to the bottom of the tube, and post an update.) Edit: I remembered that I did this last fill-up with the bike on the centerstand, usually I do it on the sidestand. So I went out and checked - the fill level was about the same both ways. I think that if you were to want to get as much fuel in the tank as possible filling while on the sidestand would get more because the tube is angled and therefore higher on one side to let more air out/fuel in.
Dan CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650 |
#38 |
Thanks for posting the update, Dan.
#40 |
You can do this mod without taking the tank off. The problem with the float is the length of the arm is too short. Yeah, you can bend it down, but it will only reach so far. I ran the tank almost empty, with the fuel pump exposed.
The furthest you can bend the wire will still leave the fuel pump covered with 3 inches of fuel. More than enough to consider as reserve and coverage. I measured with a wooden stick, while conducting this experiment. If you want the float to go lower, then you'll need to take the sender unit out and fashion yourself a new longer wire. If you do that, then you can have a more accurate reading up towards the top all the way down to a considerable reserve. If fact, if I were to do this, how it's pictured, in the above instructions, I'd bend the wire to get the float even with the bottom of that sender. Not 30mm above. Because the fuel pump sits way under that bottom plate in the lowest sump of the tank. Again, about 3 inches below. |
#41 |
Range
The most I've ever done is 210 miles and the tank took 14.3 litres.
The engine was spluttering. 66.5 mpg UK |
#42 |
How do you know you got 66.5 mpg exactly? The odometer rolls on 1 mile for every 10 actual miles driven. And that's with a 19" wheel.
#43 | |
When I use the GPS to track my trips, I wasn't aware of a great difference between the odometer and the GPS. On tomorrow's ride I will check the difference. jb
2016 Honda CB500F......2017 Triumph Street Twin 2014 XT 250........ |
#44 | |
![]() My GPS doesn't show tenths of a mile, only whole miles. So as soon as the GPS turned 100 miles, I stopped the bike immediately to take a photo, not my best picture, but good enough to see. ![]() The miles were all ridden on the straight and level, when a GPS is most accurate, and in an east-west or north-south direction. That's one thing about Florida, there's lots of straight and level. At the same time I took a photo of the RX3's odometer: ![]() It shows 105 miles. Five miles greater than the GPS reading. By my math that is a 5% difference. The only road nearby that has mile markers is the Interstate. And I don't ride interstates on the RX3. jb
#45 |
