#31 |
Sorry for the late response! As W&G stated, seems a bit fat but may work for you. Check th plug after a while. One thing about the off-idle lean pop (hand barely on the throttle, just cracked). You may also be able to work this out by fatteing the idle mixture a 1/4 or 1/2 turn. I ended up setting my Rhino (167FMM) at 2.25 turns out (115/30 jets) and it stopped. Great throttle response now.
#32 |
With the choke closed is hard to start, choke open it starts wright up.
#33 |
Thanks,the bike running pretty good with no noticeable popping if it does I will adjust the idle mixture screw.
#34 |
Hey Chuck, in the second pic (first page) with your new tires, is it me or does that front tire look backwards???
#35 |
I went with the rotation arrow on the tire , I hope it's not a factory error.
#36 |
Arrows work! Must just be the tread design then. As long as you can drag a knee in a corner, it's on right! :-)
#37 |
Good one
#38 | |
#39 |
Great info
#40 | |
