Old 05-17-2015, 01:51 PM   #31
Of course, one could set the Jaycar Speedo Corrector somewhere in the middle, and he would have a 5 percent 'optimistic' speedometer, and a perfectly accurate odometer.
I'm betting that a tire change to a different aspect ratio would result in nearly a 5% difference.
Old 05-17-2015, 01:53 PM   #32
I don't think it would be that hard to waterproof the case. Also, one could mount this unit under the pillion saddle, and extend the wiring to the dashboard. However, I do appreciate your concerns.
This would be my approach: http://en.wikipedia.org/wiki/Self-amalgamating_tape
Old 05-17-2015, 01:55 PM   #33
G19Tony   G19Tony is offline
G19Tony's Avatar
You're welcome.
I just sent another email to Jaycar. Here is the content of the email. I will post his reply as soon as I receive it.
Dear Sir,
I am attempting to put together a group purchase of your Jarcar Speedo Correctors from the United States. However, several people have expressed concerns regarding your statement in the User Manual which says, "never get any part of the module wet." Is this unit water resistant, or is it easily damaged by moisture? Can it be used reliably for motorcycle installations? Thank you.
Thanks, Spud. Looking forward to his reply.
Honda CB300R ABS
Old 05-17-2015, 02:07 PM   #34
Originally Posted by oldqwerty View Post
Overkill? Of course, but more than enough means never having to say spizz-zzzit.
I'm going to use that line at work.
Old 05-17-2015, 02:13 PM   #35
Originally Posted by jimjr21 View Post
I am in for 2 minimum. Have to talk to the other local owners. Maybe 4.
Thanks, Jim.
Old 05-17-2015, 03:43 PM   #36
Indeed, that's why it's nice to be able to calibrate the speedometer/odometer if you change tires, or the tread wears down on knobby tires, et cetera. I am starting to think it might be advantageous to locate the Jaycar Speedo Corrector under the pillion saddle, near the ECU. This area is not only protected from moisture, but it allows easy access to the unit whenever you want to make an adjustment.
Adjusting the Jaycar unit is as simple as turning one, or both of the potentiometers, and you can do that with the screwdriver in the tool kit, which is stored under the pillion saddle. In contrast, adjusting the SpeedoDRD is more involved, and that speedo corrector costs $70.
Old 05-17-2015, 03:51 PM   #37
oldqwerty   oldqwerty is offline
All electronics will succumb rapidly to getting wet. Waterproofing electronics is very easy. Silicone bathtub caulk does a fine job. Heck, all those billions of old school small block Chevy engines out there have been running since 1954 with the intake manifold ends sealed with gorilla snot of one form or another. Permgasket makes a half dozen products that will work. 3m makes maybe 1.2 billion different products that will work.
"Thou shall not Zong" is not a commandment.
Old 05-17-2015, 04:04 PM   #38
As always, thanks for the great tip, Weld.
You can buy the Scotch brand of that tape at Lowes.
http://www.lowes.com/pd_158594-98-22...ductId=3127861
Old 05-17-2015, 04:25 PM   #39
It's Monday morning in Australia, so I hope I get a reply from the vendor today. I think this unit is an excellent value. I'm sure it would cost me more to make one of these units myself than the price the vendor is charging.
Old 05-17-2015, 04:29 PM   #40
I really like the Permatex Black RTV; I use it all the time to seal the rocker cover gaskets on my two Hondas.
http://www.walmart.com/ip/Permatex-U...Maker/16777009
Old 05-17-2015, 05:07 PM   #41
ArExThree   ArExThree is offline
ArExThree's Avatar
If this unit is as user friendly as stated and is available at the estimated price...Sign me up for one. I agree that the waterproofing issue should be a minor fix. Thanks for investigating this option for all RX3 owners!
Old 05-17-2015, 05:12 PM   #42
Thanks for you kind words. You are added to the list.
Old 05-17-2015, 05:51 PM   #43
Last reverse engineering of electronics I did was a heat controller for reptiles. Cheapest source was $39 plus shipping. Home built was $7-8 dollars when bought in lots of 10.
Definitely overkill, but you already have it on hand, so good choice for you.
Old 05-17-2015, 09:26 PM   #44
Agreed. You'd probably be happy with Permatex clear, which is a little easier to remove if needed. It begins the curing process in 15 minutes, and cures fully in 24 hours. Good stuff.
Old 05-18-2015, 09:12 AM   #45
jimjr21   jimjr21 is offline
The very best way to find your roll out is what I call the oil spot method.
On a clean surface put a single drop of oil (any liquid will do) on your front tire. Roll bike straight and upright to put tow linear marks on the ground. Measure distance from front edge to front edge. This will be your true roll out including any flex in the tire carcass.
Use this measurement to input for speed calculations.
Currently In the garage in various states of running (or not) order
2015 Rx-3 super speedy blue
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
1952 Ariel Square four
