02-27-2014, 11:03 PM | #31 |
I'm not a photoshopper, but, I'm painting my rims black.
03-19-2014, 09:39 AM | #32 |
ordered up wheel bearings for it yesterday... took a while to find a few of them, since they are nonstandard bearings... hardest one to find was for the cush drive... a 15mm bore with a 52mm OD....LOL turns out theres an alternator bearing thats just the right size out there... so i will hopefully get the bike totally together and safely rideable within the next week or so... still need to fab a bracket for the rear brakes though... anyone have ideas?
03-19-2014, 10:47 AM | #33 |
Can you get the bracket that was meant for the caliper, and then weld tabs on the swingarm to match it?
03-19-2014, 10:48 AM | #34 |
On mine i modded the factory bracket http://www.chinariders.net/showthrea...ecracer&page=2 have a look here . hope it helps
03-19-2014, 10:52 AM | #35 |
hmm... i dont want to chop up the factory bracket, since i still want the ability to use the stock wheels... but something along those lines may work.... gotta sit down and see what i can come up with....
03-19-2014, 10:54 AM | #36 |
the rear caliper and everything is still the stock caliper... if at all possible i want to make this comversion completely reversuble in case i want to ride in a dual sport event....
03-19-2014, 11:03 AM | #37 |
If that's the case, I'd track down a second swingarm. Undo the shock bolt, drive the pivot bolt out and slide the swingarm away.
03-19-2014, 11:09 AM | #38 |
if i had the money in the bike budget i would... but thats pretty well depleted right now.... i will have to see what i can come up with in terms of an adapter....
03-19-2014, 11:58 AM | #39 |
PM sent . please check
03-19-2014, 06:32 PM | #40 |
Behold my quick manipulation!
Jon "MotoSquirrel" "Complete newbie, and damned determined." |
03-24-2014, 03:58 PM | #41 |
well saturday i got 4 out of 5 bearings in... turned out that i ordered one for the back wheel incorrect...i ordered another of them and hope to have it soon...other than that its almost done... still working on the brake extender though...
03-25-2014, 10:12 AM | #42 |
this looks pretty sweet, I'm due for a new set of tires soon, I may go for some street ones instead of knobbies
03-29-2014, 09:06 AM | #43 |
got the other wheel bearing in, and had a bit of fun.... even though i still have no back brake....
03-29-2014, 11:40 AM | #44 |
Looks Good . I have never been good at getting the front wheel up like this. The Goldwing powered up once . Yikes thought I was going to die.
03-29-2014, 12:02 PM | #45 |
i am not gonna lie... its scary at first... the wierd part is i can ride a wheelie on my mountain bike at balance point, which is a far steeper angle, for far longer than i am comfortable with on the motorcycle... its pretty easy to power it up, due to the large rear sprocket, its currently geared sligghtly shorter than the stock 17/56 gearing...its a 13/45 520 chain gearing... i am probably going to get a 38 rear for it eventually, but its kinda nice to be able to hooligan it a bit...LOL i may keep it this way for a while...
