Old 03-30-2012, 02:39 AM   #31
I can get "plastic canvas," or vinyl weave at a crafts store. Do you think 7 holes per linear inch is too small?
http://en.wikipedia.org/wiki/Plastic_canvas
Old 03-30-2012, 08:40 AM   #32
katoranger's Avatar
I think that the smaller holes will quickly clog. One thought I had. Drill a stock fender with alot of 3/16 holes. Maybe 1/4". I don't think anything smaller than a 1/4" will hurt anything.
Old 03-30-2012, 02:22 PM   #33
Originally Posted by pete
You've got skills! Did you make that on a milling machine? I can see the fitting that joins the two reservoirs; does fluid fill one cylinder and then dump into the other?
Most of its made in a lathe apart from the flats that were milled..
oil goes in one section flows across though the brass nipple into
the other sction then out... It was only going to be one section but
I had the room so made a second section in the end..
I have a lathe & mill in my home shop..
By petenz at 2012-03-29
Simply genius! Thanks for sharing that with us. I might think about a similar project for my XR.
Old 03-30-2012, 02:23 PM   #34
Too small clogs the holes, too large allows the mud to clog the cooler. it might just take some experimentation.
I still like the cooling ducts.
Old 03-30-2012, 04:27 PM   #35
I like that idea a lot, Allen! Thank you.
I think it would be pretty hard for any sizeable rock to make it past a 1/4" hole in the fender. Also, I can drill 3/16" holes, and enlarge them later if I wish. In addition, I don't need to worry about purchasing and attaching mesh to the fender, and I don't need to worry about rusting steel.
I am considering arranging the holes in rectangular blocks, as shown in the photograph below.
If I don't like the way the holes perform, I could always cut out the rectangles later, and install mesh. :idea: What do you guys think?
Old 03-30-2012, 04:38 PM   #36
...Too small clogs the holes, too large allows the mud to clog the cooler. it might just take some experimentation.
The radiator duct fender is indeed, a "cool" idea. Thank you for bringing it to my attention, Weld. I wish I could see one in person; it would help me decide if I like the way it looked on my XR650L motorcycle.
I think I now realize how the scoops work! :idea: The forks pass the fender in the middle of the scoops. However, the forks don't completely block the air scoops; the forks merely reduce the size of the hole in the air scoops. The air exits the rear of the scoops, and is deflected downward toward the radiators on either side of the frame.
It would appear the size, and placement of the fork scallops is critical. I'm not sure one of these fenders designed for a Honda CRF would fit my XR650L. :?
Old 03-30-2012, 04:41 PM   #37
A top tip for you Spud.
Use a STEP drill from HF to drill the holes from the inside. This will self-deburr and leave a perfect result.
Old 03-30-2012, 05:01 PM   #38
I continue to like FastDoc's idea of employing "summer" and "winter" fenders. Instead of installing some type of velcro "bra" to the oil cooler in colder weather, I could just install the "winter" fender which lacks the air holes.
Speaking of oil cooler "bras," what is a good material for this purpose? My oil cooler is a 4-inch square. Therefore, if I had a rectangular piece of material 4" wide by 10-1/2" long, I could secure this material around the oil cooler with a velcro strip.
I thought about installing a Jagg oil bypass, but my hose lines are too short to accommodate one of these units.
http://www.jagg.com/by-pass.htm
Old 03-30-2012, 05:07 PM   #39
As always, thanks for the good tip, Doc. I see the step drills bits are on sale at Harbor Freight.
http://www.harborfreight.com/catalog...tep+drill+bits
Old 03-30-2012, 05:27 PM   #40
Just wrap some tape on the bit at the correct depth so you don't cut too big a hole.
Used in plastic it gives a very nice result.
Old 03-30-2012, 05:27 PM   #41
If you don't ride below freezing, I can't see that a cooler bypass would be necessary. Automatic transmissions have an automatic bypass valve for that purpose, but it doesn't activate until it's really cold out.
Old 03-30-2012, 07:09 PM   #42
As always, thank you for the excellent advice, Weld. I don't have room to install the oil bypass, and I didn't want to spend the extra money any way. I feel better omitting the oil bypass based upon your reply.
Old 03-30-2012, 07:33 PM   #43
Heck even on an airplane if it's too cold we just put duct tape over the oil cooler. I imagine the same 'technology' would work on an XR.
Old 03-30-2012, 08:25 PM   #44
Yes, but the "fancy schmancy," oil bypass valve is much more "chic."
Old 03-30-2012, 11:17 PM   #45
Yesterday I fitted the front fender to its final configuration with the oil cooler. The factory position of the fender will not accommodate a centrally mounted oil cooler, so I needed to move the fender out from the frame about 1-1/4 inches. Here is a photo of the fender in its final position.
I got the clearance between the oil cooler and the fender by shimming the fender lower. I lowered the two front bolts of the fender by 9/16-inch. I lowered the two rear bolts of the fender by 11/16-inch. I am still waiting for a final brass fitting before I can plumb the oil cooler into the bike's external oil line.
