Old 01-13-2012, 08:20 PM   #31
larish41   larish41 is offline
that is the crankcase "oil separator"it should contain a nylon/ foam type material to capture & condense oil vapors, then return them to the crankcase
Old 01-13-2012, 08:23 PM   #32
Sounds better than my guess! :wink:
Old 01-13-2012, 09:54 PM   #33
AustinConnell   AustinConnell is offline
That is what I was thinking.
Still waiting on the rebuild kit. I've decided that I'm just going to start with the head gasket replacement. This should get me running long enough to purchase another bike. After that, I'll decide whether I want to rebuild the entire top end or not. (unless I get it all apart and the rings, piston, and cylinder are totally shredded!)
Old 01-14-2012, 12:30 PM   #34
I never got mine all the way apart. I discovered I couldn't remove the head with the engine in the frame. At that point, for my project, I decided it was more trouble than it was worth and sold it as is (was?) :roll:
All I know is the valves were in spec and there was still little compression, maybe 75 PSI max, and the motor would not start as a consequence.
Old 01-24-2012, 10:01 PM   #35
UPDATE!
I received some of my parts today and plan to be tackling this through the week.
On an even better note, I got my hands on a legitimate service manual for this exact model. (not some random bike that is "close") I will be working on making this available to zongshen storm owners!
Will update soon again![/u]
Old 01-24-2012, 10:16 PM   #36
Thanks for keeping us in the loop.
I had an official manual too but I threw that in of course when I sold the bike. It was a pretty good manual.
Old 01-27-2012, 02:16 PM   #37
So last night I began working on this. I pulled the motor out
of the frame. Which wasn't as difficult as I thought. It's
held in with less than 10 bolts. I was working alone though
so it was a bit awkward at times. The main bolt that actually
holds the engine and the entire swing arm was the most
difficult one. There are lots of cables that must be
disconnected prior to removing the engine and you want to
make sure to drain the oil before you start messing with
anything unless you prefer a big mess. I didn't get to take
as many photos as I would have liked, because my sister is
borrowing my dslr. I snapped a few for reference with my cell
phone though. Once I got the engine removed it was fairly
simple to remove the sproket in the head, the chain
tensioner, and the head itself. What I found after further
inspection, is that the gasket was definitely bad and the
valves were not seating correctly. They have a good bit of
deposit caked onto them. The piston is showing the same
symptoms. I will be attempting to clean them both tonight
more than likely. Any tips for removing the carbon deposits? Questions comments?
Â
Â
ÂÂ
Old 01-27-2012, 02:24 PM   #38
This is another view of the valves
Old 01-27-2012, 02:32 PM   #39
Just for fun
Old 01-27-2012, 04:02 PM   #40
Good work. I think you'll have this sorted inexpensively soon and be able to enjoy your bike! :P
Old 01-27-2012, 05:07 PM   #41
thanks doc, I'm certainly hoping this will solve most of my issues. I don't wish to become frustrated with this project.
Also, for reference,
Old 01-27-2012, 05:29 PM   #42
I just came across some pics of mine. It was a very good looking and comfortable bike. Just wish I got to ride it!
Old 01-27-2012, 05:32 PM   #43
Not the best pics these are when I picked it up before I cleaned it up.
Old 01-27-2012, 05:38 PM   #44
It's still a sharp looking bike nonetheless. As for the comfort, its the most comfortable bike I've ever ridden. The pegs are a couple inches high for me, but I've got long legs. The seat isn't as intrusive as others are. 8O it just needs a bit more power. I do hope that I will gain quite a bit once this all sorted out.
Old 01-28-2012, 01:15 PM   #45
If you have a bench grinder, see if you can find a brass wire wheel for it. Make sure it's actually brass and not brass coloured; try a magnet on it.
A brass wire wheel would be suitable for removing the carbon from the valves without removing the coating. Once the valves are clean, you can inspect them to confirm that the seating area is in good order. If it is not, you can lap the valves in by hand. A nylox brush in a drill would be a good solution for removing the carbon from the combustion chamber. All of this assumes that you have a valve spring compressor that will allow removal of the valves.
If you choose to use a nylox brush in a drill to remove the carbon from the piston top, place a shop vac hose right above the piston to remove chunks as they are removed. It's imperative that the schrapnel isn't allowed to fall onto the rings and remain there. Once the piston is perfectly clean, you could polish the piston top with a dremel and some white polishing compound, so as to prevent a porous area for carbon to collect in the future.
