Old 12-09-2011, 10:23 AM   #31
It's not so much elevation in your case as the rotten muffler. Do you plan to fabricate a new muffler?
Old 12-10-2011, 08:59 PM   #32
katoranger's Avatar
I think first step will be making sure it runs. Then I may do something about the exhaust. I have a newer xr80 exhaust that maybe could be made to fit.
Or open it up and rejet.
Old 12-12-2011, 02:36 PM   #33
katoranger's Avatar
I opened the air box to find the remnants of a filter. Ordered a new one. Hopefully it comes by the end of the week.
Thinking more on the muffler. I have the new xr80 pipe. They are a dime a dozen compared to the older ones for the twin shock models.
I am wondering if I can cut the end off of the new one and slip it over the original using the baffle from the newer pipe.
The stock exhaust seems pretty solid until the last six inches. The inside look shot. Probably loud too.
Old 12-12-2011, 03:16 PM   #34
katoranger's Avatar
I think I can make this work.
I cut a late model xr80 exhaust off at the forward seam. This was a dented up one that didn't have any ebay value. Looks like it has a use now.
Inside the late model xr80 muffler.
The newer one is straight. The older one is tapered some. I think I can slip it on and weld it around at the end.
Weld, I don't have your skills at fabbing a whole new part. This will have to work.
Old 12-12-2011, 04:07 PM   #35
katoranger's Avatar
Looks like its going to work.
I just went out and started cutting. Did some grinding and maybe later some welding.
I made some slits for the baffle mounts to slide into.
Also ground a slot for the hanger on the other piece.
Now I need to decide how to secure it together. I am almost afraid to weld it. The metal is so then on the old exhaust. Thinking about some keep of muffler putty and pop rivets.
Old 12-12-2011, 04:40 PM   #36
The muffler putty will likely work OK in that application. It will hold the pressure, but it's brittle and will crack/flake off if there's any movement.
It's been holding the multiple holes/repairs on The Dirt Rat 2, but I will be looking at a replacement muffler after work tonight.
Old 12-12-2011, 04:42 PM   #37
I bet red RTV silicone would be better, especially if the gaps are not too large that need to be filled. This will take the inevitable flexing and vibration better I think.
It seems to take heat OK. My BSA mechanic uses it on the slip joint where the header inserts into the head on all the BritBikes he does.
Old 12-12-2011, 05:27 PM   #38
katoranger's Avatar
Red RTV might be the answer. It is pretty ridgid slipped together. The RTV with about a dozen rivets or self-tapping screws may be enough.
New points installed. Set gap. Sprayed a touch of carb cleaner in the intake.
One kick and it fired up. :wink: Looks like we have a runner. Need to get some tires coming.
Old 12-12-2011, 05:54 PM   #39
Hey great news!
You gotta love the Honda XR line!
Old 12-12-2011, 06:46 PM   #40
katoranger's Avatar
Carb installed. Required a few steps and parts from original to fit.
I had to swap the choke handle so it would clear the frame and install the two mounting studs from the original carb. Also used the original top piece of the carb since it is straight and not curve. Other than that it seems to be a bolt in.
Next I need to flush out the tank and install a new fuel line and filter.
The cable seems to hang up. I recommended a new one after as part of the restoration.
Old 12-12-2011, 06:55 PM   #41
Awesome!
What's with the oil leak? Just the valve cover gasket?
Old 12-12-2011, 08:12 PM   #42
katoranger's Avatar
I sprayed some penetrating oil down the cylinder. That is what sprayed out after giving it a few kicks.
Lubed the top end some.
Old 12-12-2011, 08:56 PM   #43
Perhaps you can practice welding on some of the remnants that you cut away. I'll bet that your Hobart would do a fine job. If you're not satisfied with the results, you could certainly rivet it together.
I got an excellent tip from a gentleman on the TS forum that Kato found. He puts a really thin film of grease on any gaskets, which helps to seal and makes them reusable. If you need to remove the valve cover, perhaps you would benefit by applying a thin film of grease to the gasket or o-ring.
Glad to hear it runs! Have you found a rear fender yet?
Old 12-13-2011, 12:20 AM   #44
The new carburetor looks great! I agree with FastDoc; you have got to love the Honda XR motorcycles!
Old 12-13-2011, 08:21 AM   #45
katoranger's Avatar
I am going to try and weld it. The practice on a some of the scrap is a good plan. I can get the hobart set up on that.
This may be a Thursday activity.
Grease on the gasket. Good idea. I think I will be checking to valves while it is here too.
