#31 |
Indeed, you did a very nice job!
![]() Spud ![]()
#32 |
Wow, how did you mill the aluminum?
#33 |
Thanks for all the compliments on the work . All the work was done with, 3" abrasive wheels , sawzall , hand files , drill press , bench grinder and sandpaper . I'm thinking how nice some real frabricating equipment would be . I have worked with end mills before ,but while in that position i could not afford projects sadly
#34 |
Maybe I missed it but...how come nobody has asked about the (I'm assuming) 'tool holder that looks like an exhaust' on the left side?
#35 | |
#36 |
I met a guy at a car show who had customized a '49 Ford, and he did some mild aluminum milling with a router. I think it's workable for projects like yours, since aluminum is so soft. You could set a router up in a table and increase the cutting depth incrementally until you've milled away what you wish. You could even set up stops to make the passes repeatable.
It's not an end mill, but it would do the trick. Nevertheless, excellent job free-handing it. Thanks for the pics.
#37 | |
#38 |
You could even use a large grinding disc on the tablesaw, just be careful with side load. A cheap X-Y table could turn the drill press into a cheap milling table. I would even try 1/4" router bits in the drill press. Can you tell I've thought of these things before?
#39 | ||
#40 | |||
#41 |
Thanks, racer.
#42 |
Just love the look of the bike!! Did you mod. the side plastics your self?
Love how your bike sits hight on the rea,r exact look i want on mine.. Whats the best tool to cut the plastics a dremel? ![]() ![]() great job you done with it.... |
#43 | |
#44 |
I just reread this topic and realized i had not said anything about the weight savings or not . I had not weighed things apart but as assemblies . The front wheel , tire and brake rotor ,were so close in weight No change there Zong sierra to supermoto aluminum . Rear assembly saved about 2 1/2 pounds . Lifan steel rim to supermoto aluminum . Also the front wheel speed counter has the speedometer ,just a tick fast / I think a 110/80 or a 120/70 front tire would be right on , currenty it is a 110/70-17
#45 |
Do you plan to try a different size tire, or just call it done?
