09-29-2016, 10:56 AM | #31 |
I wonder if the HAWK swing arm is similar in design to my Bashan swing arm (or the TT250)... a future mod I will have to look into
11-13-2016, 12:40 PM | #32 |
After reading this thread I drilled, tapped and put a grease zerk on my swingarm and pumped it full of grease. Now i know it has grease in it. I did this on atv and utv as well on every where there is a bushing.
11-13-2016, 12:55 PM | #33 |
Jerry, should I do this? I have pulled the bolt and liberally greased it. I have considered this but with out seals on the bolts I wonder about having a mess. I don't think it's quite necessary in my case since I don't encounter too much wet situations. On the other hand I might think differently if I lived in gritty salty Houma la.
11-13-2016, 01:20 PM | #34 |
It's not necessary. It's a lot easier to pump a little grease it it than to pull the swing arm Bolt. On the atv we go through a lot of water and mud. Keeping it full I never have to worry about water getting in it. It doesn't leave a mess.
06-10-2019, 04:29 PM | #35 |
Since this is still coming up under google as the number #1 spot I thought I would add my fix. My bushings went bad as well,on one side the rubber dissolved and on the other the metal bushing split in two.
After knocking the remaining bushing out, I scrubbed out the swingarm tube, bought 1/2" copper pipe and heater hose. the copper fit over the swingarm bolt perfectly, and the heater hose fit over that and into the swingarm snugly. I ran the pipe and the tubing all the way through for rigidity, and greased the bolt and end caps with heavy marine grease when I put it back together. $4 spent and about 90 minutes and the boy is back on the road. Last edited by jasonic; 06-10-2019 at 04:43 PM. Reason: clarity |
