#31 | |
Also....maybe that's why mine does better on the 127.5 now. I have the FMF TC2. It breathes VERY freely. I got a flat spot out of the 125 at higher R's once I installed it. Can you run a louder unit in your races????? It's light, easy to mount and cheap......
#32 |
Ebay seller "Partsdepot" for the cam
Today was the first test ride with the Protapers installed with the new bar height and bend it has made the bike feel a lot more stable and comfortable to ride. Closing in on 9000kms on the Q and no problems with the engine at all, frequent oil/filter changes with 20W-50 4stroke oil and checking the valves is the key. Also talking with Racetech about some "gold valve emmulators" and possible different front/rear spring rates to improve the suspension woes
Bikes: Yamaha 1974 Yz125a, Yamaha 1974 Sc500, Yamaha 1977 Rd400, Yamaha 1978 Yz125, 1988 Harley Davidson Xlh 883, 2006 Ktm 450 smr, Ekeleton 2006 Beast 200cc the worst bike I have ever owned |
#33 |
So it appears that I have been doing things wrong this whole time, I mean from what this guy in his Craigslist add says about his Qlink "90 miles per gallon and a top speed of around 90mph" I've got a lot to learn
http://gainesville.craigslist.org/mcy/2576099374.html Great bike. Hate to sell for so cheap but life has gotten in the way and it has to go. Its a 2009 supermotard or moto which ever you perfer. Lots of aftermarket goodies installed. Call or text. 352-246-1595:First come first serve. Will trade possible but hass to be a sportbike. If its a sportbike send all offers( pretty ugly young or old)*MUST GO NEED THE MONEY BY THIS WEEKEND..WILLIN TO DEAL~~K ********BEST CASH OFFER OR TRADE OFFER. UP ALL NIGHT TEXT OR CALL I SAY UP LATE..* - The bike is Electric or kick start. I never have to choke this bike when starting. -Bike is designed to carry a passnger if nessary. -55watt headlight. Has high and low beam. -Has a reckon race clutch. For speedshifting. -Muntzi 39mm race carb. Jetted. - Standard 5 Speed ( 1 down 4 up) - Tach and speedo and also a LED Gear Indicator -New fluids ie Brake,Gearbox,Motor oil all sysntic -Approx 5k -Underbodys tail elemator. -Aftermarket turn signals -Aftermarket slipon pipe -Tires have good tread - 90 miles per gallon and a top speed of around 90mph **********NEEDS********* Chain-428 is the size of chain needed Rear Sprocket- I have already ordered this part from local dealer ship and the shipping company sent the wrong sprocket...The new sprocket is coming from jtsprockets and its a 44t
#34 | |
2008 Yamaha WR250x 2006 Honda CRF250R Sold: 2002 Suzuki SV650S, 2009 Qlink XF200 |
#35 | |
![]() 90km/h maybe. I see that he also has the highly coveted "Underbodys tail elemator". ![]()
#36 |
#37 |
I get 100kph indicated with a pushrod 150 and a 135lb rider. im at sealevel with a oversized airfilter and perfectly dialed carb. it could use another tooth on front sprocket even[/i]
#38 |
That's great, trevort!
![]() I was still grappling with the Stage 1 cam change until I just spent the last 2 days on Q. (sorry...no pics or I'd post) I have the higher gearing as documented....but man...up over 2500' elevation....the little 200 just doesn't haul my 200 lb Italian Carcass as it should, even with the jetting and FMF TC2. She runs perfect otherwise. I'm going to try the cam.......and see....then I may drop one tooth back to stock on the countershaft and keep the little rear sprocket. With the current setup, my crawl-speed trail riding requires a lot of clutch. Other than minor fine tuning.....I LOVE this bike! ![]() I looked at it yesterday after 100 miles of Gold Country Twisties and muttered...."Are you sure you're not Japanese??????" ![]()
#39 |
Small update on the new bars and mounts installed on the Q, still waiting on parts for the handguards
![]() Good luck on the tuning 2LZ your bike always looks great
