#32 |
definitely well inflated....
been around bikes for a while.... honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7 all about the Tao MotorsTBR7 http://www.chinariders.net/showthread.php?t=25553 |
#33 |
Some important things to note.
The Hawk airbox mod does not apply to the TBR7, it's a different lid that uses a rubber snorkel. The TBR7 uses a H6M headlight bulb and all the LEDs I've found for it dont have high and low beam, just bright and brighter. The TBR7 has a resistor cap so it needs a non-resistor spark plug. Running a resistor plug in it will cause premature coil failure. The frame is not the same as a Hawk so the standard CRF performance exhaust will need some additional work to install it. The rear monoshock is very poor quality and will be bouncing like a pogo stick within a couple of months so plan on buying an aftermarket replacement. Do not over torque the rear axle nut, you'll be buying bearings soon if you do. 35ftlbs and some loctite are sufficient. And lastly do not follow Motocheez's video on changing fork oil. Take the time to remove the front wheel and each fork from the triple tree and drain them from the top cap by turning them upside down.
#34 |
#36 |
![]() ![]() thanks so much for the tips one legged rider The Hawk airbox mod does not apply to the TBR7, it's a different lid that uses a rubber snorkel. noted �� The TBR7 uses a H6M headlight bulb and all the LEDs I've found for it dont have high and low beam, just bright and brighter. i am just installing some LEDs with a relay... myself. stock lights are insufficient for night riding The TBR7 has a resistor cap so it needs a non-resistor spark plug. Running a resistor plug in it will cause premature coil failure. what is a resistor vs non resistor plug.... how do we find the right plug? preferably an upgrade. is it as simple as the same plug with out the R ?? i did find this cross reference chart/ guide http://www.xenonzcar.com/z31/files/24_SPARK_PLUGS.pdf ? The frame is not the same as a Hawk so the standard CRF performance exhaust will need some additional work to install it. i happen to be installing one soon.... we will see i guess.... maybe a bracket or two needed.... The rear monoshock is very poor quality and will be bouncing like a pogo stick within a couple of months so plan on buying an aftermarket replacement. noted �� according to taopartsdirect it is 305mm distance from middle-eye to middle-eye but ifmthere ar e any recommendations please list them �� Do not over torque the rear axle nut, you'll be buying bearings soon if you do. 35ftlbs and some loctite are sufficient. noted �� And lastly do not follow Motocheez's video on changing fork oil. Take the time to remove the front wheel and each fork from the triple tree and drain them from the top cap by turning them upside down.] noted ��
been around bikes for a while.... honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7 all about the Tao MotorsTBR7 http://www.chinariders.net/showthread.php?t=25553 Last edited by Kenstogie; 04-15-2020 at 06:15 PM. |
#37 |
Spark plug, yes if it has an "R" on it then it's a resistor plug. The easiest way to know for sure is to put your multimeter on it. 5000 ohms = resistor plug, 0 ohms = non-resistor plug.
This is the shock Dan and I use and really like. His is a 325mm and I'm running the 290mm. The biggest one I could find at the moment is a 295mm, (which would lower your seat 1") but I'm sure if you keep looking you can find a 305mm. https://www.amazon.com/ZXTDR-Suspens...bsorber&sr=8-8
#38 | |
#39 |
Seems like a lot of trouble to go through. Not sure of how reliable it will be after either. Just buy a non-resister plug.
#40 | |
that means (according to the ngk chart above) D-12 mm thread/5/8, P-projected insulator, R-resistor type, 8 heat rating, E-19mm reach, IX=hi perf iridium with a 9 mm gap.... from what i saw all the iridiums were resistor types , not sure how much the heat rating matters but you could run DP6EA9 DP7EA9 DP8EA9(closest) DP9EA9....all standard plug types and unfortunately no iridiums in the bunch
#41 |
to compound matters, Kawasaki lawnmowers typically use a resister plug as well as a 5k ohm plug, and the coils typically last many many years.... i have a 1986 deere 185 running a 17hp kawi, runs the 5k plug cap as well as a BPR5ES... LOL but thats a japanese coil, not a chinese one....
#42 | |
https://www.ebay.com/i/142956407548?...BoCYM4QAvD_BwE
#43 |
Jetting for TBR7
So i picked up my new TBR 7 months ago and it rides like a slug from mid-range to full throttle. After reading this entire thread on TBR7, i didnt see anything on jetting the carb.
i did read in other section to get a new carb, so i went with an accelerator type and a cone air filter. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 i bought these jets... https://www.ebay.com/itm/10pcs-Carbu...72.m2749.l2649 i bought this exhaust... https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 and i live in Ground Zero, NYC... I am at sea level. Can someone suggest a good combo of main and slow jet replacements? I hope im not posting in the wrong space and if so, please direct me as im taking a chance with these china bikes that im starting to doubt because of all the reading that im doing...lol..and the loose front disc bolt and the lack of manual that Tao couldn't offer me when i asked. Their method is, "tighten all the way plus 1/4 turn"...exact words! Also wanted to add, a replacement CDI since people recommending electronics upgrade or just cap? and plug? Has anybody got the Kickstart to work? Help please! My real bike is a CBR1000rr...and they stole the KLR650...so i went china...if this don't work im going back to Japan! DRZ...Yamaha, KLR again, CR? Im open people as I dont want to fix this bike forever!!! Last edited by Aloha357; 04-16-2020 at 11:18 PM. Reason: Add more info! |
#44 | ||
also heres a non resistor E3 plug that might do the trick.... e3 110... https://www.amazon.com/E3-Spark-Plug.../dp/B07B6SF2XJ
#45 | |
ETA, you might want to get a new CDI unit, I had all manner of issues that felt like fueling, but were caused by the CDI getting hot and failing. these bikes are cheap for a reason
