03-24-2017, 12:28 PM | #31 |
Looks like it's just a matter of drilling four, well-placed holes in the rear handles.
03-24-2017, 01:22 PM | #32 |
I have been following him since he got his almost a month ago. He has been super helpful with his videos. He felt it had more in it too. I bet it will hit 75 or so once broke in. Should cruise 55-60 np all day.
03-24-2017, 01:36 PM | #33 | |
The engine is super smooth and quiet. I would def. recommend checking the valves before firing it up the first time to ensure they are in spec. Mine were a bit tight. Other than that make sure the bolts/nuts are good, check the chain tension, change the oil, charge the battery, check the plug gap, and put some gas in it. It fired up easily on the third push of the starter with the choke on. |
03-24-2017, 03:27 PM | #34 |
If you're not going to do a ton of off-road, this is definitely livable and just a matter of preference. My RX3 only comes with an 18/17 combo. I am thinking of getting the 19" front wheel option though but on the pavement, gravel roads and light trails, it's just fine.
03-24-2017, 03:56 PM | #35 | |
03-24-2017, 08:40 PM | #36 |
That's not a bad at all. I really like the Brozz with that tire set up. Still cheaper than a TT 250. 😝So
03-24-2017, 11:34 PM | #37 |
The Brozz is down to a few green ones left. There are still plenty of Sharks left--the red-headed stepchild to the Brozz which is probably worth worth a second look if the Brozz sells out. The Shark is near identical in features minus USD forks and a fuel gauge. Heck, the Hawk is still worth a look!
03-25-2017, 12:36 AM | #38 | |
03-28-2017, 02:28 PM | #39 |
if we assume the standard 8% inaccuracy then that is 62mph
03-28-2017, 06:12 PM | #40 |
DZ said his gps showed it was 2mph off, so not bad on accuracy with his speedo anyways.
