Old 10-26-2015, 10:42 AM   #31
peperino   peperino is offline
Does the coolant ever returns from the overflow bottle? If so, how?
Old 10-26-2015, 11:31 AM   #32
keithmaine's Avatar
The over flow (or expanding coolant) from the hot radiator flows into the tank from the bottom. When the engine cools (coolant contracts) it creates a vacuum and sucks the coolant from the tank back into the radiator.
Old 10-26-2015, 11:33 AM   #33
Its a kind of magic
Old 10-26-2015, 01:30 PM   #34
Yes, the coolant overflow bottle of the RX3 operates the same way as an automotive system.
Old 10-27-2015, 01:51 PM   #35
pepelepua   pepelepua is offline
pepelepua's Avatar
After 1st refilling and a 300 km ride, the level goes down only about 1/2".
Pablo.
Today Riding a Corven Triax 250 Touring (Zongshen RX3)
Old 10-29-2015, 08:41 AM   #36
mouradjan   mouradjan is offline
Hi, i have been using rx3 for about 10k kms.i filled radiotor water about every 1K kms.Not too much but about 100/150 ml water.Everytime when i stop the motorbike i see water coming from this hole.And this picture is taken about 5 min after running.U can see the water.
After reading your comments i checked every piece of radiotor .There is No leak.
So do u say i have to add a different coolant to change the boiling point of water? Will it work to stop it leaking?
Old 10-29-2015, 10:56 AM   #37
You will not increase the boiling point of water by adding liquids; only pressure can do that. Water has an amazing latent heat of vaporization, and it will absorb a terrific amount of heat before changing from 212F/100C.
Adding coolant / antifreeze will lower the freezing point, lubricate the water pump and prevent corrosion.
It's difficult to see from your picture, but if that's the water pump weep hole, the water pump seal is leaking.
It's difficult
Old 10-29-2015, 01:33 PM   #38
...It's difficult to see from your picture, but if that's the water pump weep hole, the water pump seal is leaking.
Yes, that hole is the weep hole for the water pump. You need to drain the oil, remove the right crankcase cover, and replace the water seal.
Old 11-11-2015, 01:58 PM   #39
Thumbs Up
Thank u Weldanegrid & SpudRider .
I changed the water seal which is in the water pump .There is one more seal in right crankcase .I only removed the water pump and changed the one which is causing to drain water from the 1mm weep hole .i have a photo of the seal .May be it may help to Rx3 owners ☺.
Old 11-11-2015, 02:12 PM   #40
You're welcome. I hope the new seal fixed the leak.
I see the water pump seal is size 12x24x6. Thanks for posting the update, and the photo.
