#31 |
I'm not sure why commented like that so I guess I need to clarify. There are a lot of good quality oils on the market and many are good motorcycle oil, I have used diesel oil for years in my motorcycles both dino and synthetic oils as well as other oil and lots of different brands. The modern water cooled engines are not nearly as dependent on the oil for cooling as our air cooled bikes are. We need better viscocity oil for lubrication and its cooling effects, so the viscocity is of more importance than the brand of oil. I also don't believe there is a great difference in Honda or motorcycle specific oils in themselves, but to my point. We buy everything from the big box stores and online anymore and the local dealers suffer. There may be a day when you need a part like now and your local Honda dealer has it and in stock ( yes some Honda parts fit some chinese engines) So buying oil from them may cost a couple of bucks more but to me it's worth giving them a little business than throwing all my money down into the big box coffers. Just my opinion
#32 | |
https://blog.amsoil.com/why-you-shou...rts-equipment/ |
#33 |
I wouldn't use anything that the manufacturer advises against using for wet clutches, simply because you don't want to unnecessarily have to replace a clutch because the friction modifiers in the oil killed the friction discs in the clutch.
#34 | |
Even with the oil cooler, T4 lasts at best 800 miles in my bike. So far the T6 tends to be pretty much roasted around 1500 miles, but for arguments sake let's call it 1200, which is still a 50% increase in oil life meaning my total cost of operation between the two oils is almost identical.
#35 |
That AMSOIL link has a good comparison of conventional versus synthetic oil and of course they are selling synthetic oil but if the testing backs it up.
https://blog.amsoil.com/synthetic-vs-conventional-oil/ |
#36 |
I love oil threads.
"Oil-use it".
#37 |
Just embrace it and let your universe expand.
#38 |
This problem is solved.
I used Amsoil 20w50 full synthetic made for air cooled v-twin bikes and compatible with wet clutches. Within minutes of starting to ride, the transmission worked better. I can shift into neutral from first now. So if you are having this problem, switch to a different oil. Rotella T4 is not the right oil for these transmissions/clutches, at least with my Lifan X-pect. This Amsoil is available at Ace hardware, among other places. I saw it and grabbed it on a whim. All shifting problems were solved instantly.
2020 Lifan x-pect |
#39 | |
Not saying that Amsoil isn't great stuff either. It's the only thing I use in my VFR (7100 10w40 synthetic) as it runs and shifts the smoothest. At $60 a gallon though, not quite something I will run in my Hawk lol.
#40 |
The test would be to put some T-7 in it at next oil change and see if the shifting problems return.
#41 | |
I’m happy with a perfectly functioning bike at this point. I don’t want to go back to bad shifting.
2020 Lifan x-pect |
#42 |
Rotella T4 15w40 is the goto for motorcyclists across the board. All sorts of bikes of all types have had nothing short of stellar performance. No fancy break-in oils or special weights for different Temps needed. All year. All climates. All conditions.
Rotella T6 synthetic 15w40 is the preferred oil. It's even better. If you can find that, use it. I found the T6 5w40 to shear a bit early. The 15w40 works amazing in virtually every single shared sump I've used it in. No slipping clutches. Smooth shifts. Air cooled or water cooled, doesn't matter. Once the warranty is up on my Moto Guzzi it, too will be switched to T6 15w40. |
