02-25-2011, 02:53 PM | #31 | |
02-25-2011, 02:56 PM | #32 | |
02-25-2011, 03:00 PM | #33 |
I don't know if it would fit an XR frame, and I sure don't need 10! Plus I did not see a price...
Happy to serve. |
02-25-2011, 03:10 PM | #34 |
Like RECRACER found out. NoEPA means you dont get anything
02-25-2011, 03:35 PM | #35 |
That's the difference in Canada. We can't tag bikes that haven't passed Transport Canada inspections, but we can import bikes and engines for off-road competition use only. So far, we don't have EPA req's for bikes, AFAIK.
We used to be able to have a special inspection done in my Province that allowed us to dual sport a dirt bike, but not any more. If it wasn't imported as a street bike, it's dirt only forever.
02-25-2011, 03:41 PM | #36 |
"Samples Available" means you can buy one for testing purposes. The engine would need EPA certificate for customs clearance. I'll find out what the sample price is and if it has an EPA certificate. I'm thinking that if it is a CG125 clone so then it should fit and bolt right in my bobber as my engine is a CG125 clone at 229cc's. Just thinking for down the road.
02-25-2011, 03:54 PM | #37 |
400cc 3 cylinder motorcycle engine
02-25-2011, 04:49 PM | #38 |
sample for testing without EPA requires pre approvals from EPA and dot if testing will be done on road and will have to leave the country within one year from entry date .EPA will require an outline of testing purpose ,meaning a company would be doing the testing . with EPA it needs to be a replacement part for an already EPA certified motorcycle . no prevision for bringing these engines for off road use . clean air act prohibits retrofitting another engine in an already EPA cleared vehicle . there may be a way for individuals to import up to 3 engines 19kw or less for personal use . 400cc would be over 19kw .
02-25-2011, 08:02 PM | #39 | |
Dropped, hammered, WOT for miles along Malibu and Angeles National Forest in hot summer days, etc., and still no problem whatsoever. Know what you're doing before you buy because storage charges in some bonded warehouse can be very expensive so don't get stuck. It's not uncommon for many businesses abandon shipments and still have transport companies come after them for transit cost. |
02-25-2011, 08:21 PM | #40 | ||
193cc here's how it works 1 meaning 1 cylinder 67 is the bore and the L on the end means 200cc class . the other is a 167fmm 1 cylinder 67 bore and m on the end for 250cc class difference is the stroke . 55.1 for the 200cc class and the 250cc class has a 66 mm stroke |
02-25-2011, 08:33 PM | #41 | |
02-26-2011, 01:01 AM | #42 |
I have to chime in and say that I have two of the Lifanoid/Honda clone pushrods in the garage. One 200 (or there abouts) and one 150 (or there abouts)
Both have been flawless trail riders for me and Mrs 2LZ. No leaks, drips, problems or errors, tons of torque for a small motor....even at high elevations. Drop them into first or second and they'll grunt my 210 pound carcass straight up a flag pole. Is OHC "better", as far as delivering more usable power? Sure! It's newer, more efficient technology that became available for them to build....the Q I'm looking to get has the Suzuki clone (like Docs and others) and it's more powerful than my pushrod Lifanoid for the same displacement. It actually had a real powerband when I rode it! Not just a bucket of grunt. The pushrods are out there by the scads, my guess being that was one of the first expiring patents bought and produced by China. I highly doubt it has anything to do with much else like cost or durabily. "Get a reliable motor, with all the legwork done and make it by the metric ton". So far, I'm not disappointed in that choice. Can't wait to get the Q though. I would also like to mention that this has been an awesome thread to follow! Great info!
02-26-2011, 11:12 AM | #43 |
I totally agree theres nothing at all wrong with the push rod engine . I don't recall hearing of many failures in these little work horse engines . my 163fml is a replacement engine ,because i bought it blown up . however it was not the engine fault . during removal i found vacuum leaks . running very lean killed it . A few other failures i seen also not the engines fault ,ingesting water creek riding . seems if you change the oil ,check the valves from time to time and check the plug for lean out . they last and work hard for ya. Most of my riding is on the streets ,so I'm always looking for a little more reserve power . power adds a safety margin when cars are around . I bought the 167fmm from http://stores.ebay.com/Porsche-944-P...=p4634.c0.m322
02-28-2011, 10:09 AM | #44 | |
From vendor "Dear Mr. Vincent Santamaria, Good day and thank you for your kind inquiry. About the 400C engine, the certification you need EPA&DOT which we do not have, and sorry. Could you please let us know more about your company and business then maybe we have chance to cooperate next time? " |
03-01-2011, 10:38 AM | #45 |
I think in Canada we can import somthing for offroad use only so we dont need EPA.
Do you know how much power the 400 makes? |
