Old 04-25-2011, 05:30 PM   #31
waynev   waynev is offline
Originally Posted by yozalo
I will change out the spark plug, it was pitch black, with the tip being blistered...
Isn't black a sign of the carb being too rich?
True...but you can't just take a spark plug out and get a proper reading, if you were checking the main jet then you would have to go full throttle for about 20-30seconds then cut the ignition and then read the plug, same for the midrange as about 5/8-3/4 throttle and same for the idle. But without doing the test like that then it's hard to say where you are rich.
Are you still running the stock plug?, they are not very good and could also lead to the black fouled plug you seen, i'd start with a fresh NGK CR7HSA, you can get them at Canadain Tire, part # 018-3670-6, there about $7.99 for a two pack.
Old 04-25-2011, 07:19 PM   #32
yozalo   yozalo is offline
I'm running the Champion spark plugs on my atv since from last year.
I'll change it out to whatever they have in stock at crappy tire. Last year when I went there, they only had the Champion plugs in stock. It seems that they stopped selling the NGK two pack ones, or it could be a coincidence. Either case, I still need a new spark plug, either it be NGK or Champion, anything is better than the Chinese ones...
Old 04-26-2011, 08:40 PM   #33
FosterVS   FosterVS is offline
Another problem here. I was taking my atv for a ride, then the atv suddenly shut down, and would not start back up again, I had to push it back home.
Everything was running fine before, but the carb was running a bit lean since I changed the exhaust to the performance one offered by giovanni. I sense something bad....
Well.... #1 make sure there is still gas left in the tank, #2 make sure the fuel shut off is on ( if you have one ), #3 check spark plug for foriegn aluminum pcs melted on it ( that's a bad sign), #4 check spark, #5 check compression.
#1 should be "make sure the kill switch isn't on". Think we've all been there...
Old 04-26-2011, 09:46 PM   #34
Good point, and also that rear tether switch can be troublesome.
Old 04-26-2011, 10:10 PM   #35
Problem was fixed....I changed the needle jetting setting to the second notch...
I removed the safety theater at the back...
Old 04-26-2011, 11:13 PM   #36
Good to know. WTH 'safety theater'?
Old 04-27-2011, 12:55 AM   #37
Safety thether I meant...
It gives me a spelling error every time..oh well
