Old 08-14-2020, 10:57 AM   #31
Originally Posted by Deckard_Cain View Post
Well this is conflicting ... lol.
The Motion Pro tool is M28.1.0 .... th eone Dan used, that you link here, Jerry, is described on the page as M27x1.0.
Pretty sure one won't work and the other will.
So any ideas all which is correct?
Look at the pictures on Ebay. M28x1.0
2004 Honda ST 1300
Old 08-14-2020, 02:51 PM   #32
Deckard_Cain   Deckard_Cain is offline
Well damn. Item description says 27mm... Pictures show 28mm measurement.
That's dumb.lol.
Old 08-14-2020, 05:24 PM   #33
That's dumb.lol.
What's even more dumb is the M27 or M28 thing doesn't matter. You need the M16x1.0 center piece to actually pull the flywheel on the Hawk, so as long as you find a puller with that thread size and pitch, you are good to go.
Old 08-24-2020, 05:40 PM   #34
Jeff Richardson   Jeff Richardson is offline
Jeff Richardson's Avatar
Originally Posted by jeffrey View Post
I found a place that has both 2 degree and 4 degree keys for the Honda 50s and 100 that are the same size as the Hawk. ADA Racing in Chandler AZ. $ 9.95. Thanks OLR.
That seemed like easier method for me.
$15 to the door. USPS
2017 RPS Hawk. Mikuni carb, 117.5 main, 25 pilot. Foam filter. NGK plug. Upgraded exhaust. 17/45 sprockets. Digital speedo. Full LED all around. U5 handlebar spot lights.
1982 Yamaha XJ1100 Maxim
Old 08-27-2020, 11:42 AM   #35
That's good to know Dan. I've never pulled the flywheel cover or flywheel off my Hawk. I assumed it would of been the same as the X22R. I'll need to order two flywheel keys.
2004 Honda ST 1300
Old 08-30-2020, 08:12 PM   #36
Wrapped up my timing key install today.
Bikes running rich, but you can indeed feel better throttle response and a bit more pep in her. Overall an easy job and well worth it.
I think it chalks up to not accurate sizing, but I was running spot on fuel mix on the stock carb, this vm26 clone must have a TRUE 40 pilot, which is larger than the so-called k40a pilot that's on the stock carb.
Looks like I'll be buying a pilot jet assortment now. I can't dial my idle mix lean enough on this jet. Air/fuel screw all the way in or out, anywhere in between just isn't right.
But I do like the 4 degree timing advance.
Old 08-30-2020, 10:51 PM   #37
I went to the local auto parts store and just bought a grade 8 bolt, and ground about 3/8th of an inch off the end of the threads. Then just thread it into the end of the flywheel and use the bolt to press off the flywheel. It works an absolute treat.
First Rule of Aviation:
The Stable:
2005 Yamaha V-Star 650 - SOLD
2015 Suzuki DR 650
2015 RPS Hawk 250 - SOLD
2016 Ural Gear Up
Old 09-01-2020, 01:09 PM   #38
OneLeggedRider's Avatar
Well yesterday we installed a 12 tooth sprocket on Jay's Hawk and now you can really tell the benefit of the 4° flywheel key. 12/33 was the best ratio for my Hawk and netted 66mph. Because Jay weighs 120lbs less we thought a 13/33 ratio would be better for him. This was apparently not the case. His 5th gear was power assisted coasting.
But anywho, his bike is flying through the gears now and accelerates much faster. His top speed is still limited to 66mph, but I think it will have to have head work to cross that barrier.
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
Old 09-02-2020, 12:04 PM   #39
It's not about top speed, It's how fast you get there. The head work will help.
2004 Honda ST 1300
Old 01-21-2021, 11:17 PM   #40
Length and width for the stock key is 14mm x 4mm and the height of the curve is 4.1mm. The offset for the 4° advance is 0.7mm
So that's simple enough, make your width 4.7mm and then cut the opposite sides halfway through the height to 0.7mm
I bought one. Measures almost identical and the difference probably not significant 14mm X 4mm and the height of the curve 4.37. the offset for 4degree .7mm Guess Jerry will confirm it this weekend.
Old 05-01-2022, 05:35 AM   #41
MDStroup   MDStroup is offline
MDStroup's Avatar
I know this is the dual sport section, but this is the thread for this, so I figured it best to ask here instead of a new thread.
Will this 4 degree key work with the engines that come on the grom clones?
Old 05-05-2022, 10:55 AM   #42
I also have a Boom Vader grom clone, used the original 125 engine for a bit, then big bore kitted it to a 141 and now I've got the ZS190 in it.
This specific key likely (probably) won't fit the crank and flywheel on those engines. This concept very well may... but getting an aftermarket CDI or one with variable timing is much easier.
There are a few CDI boxes out there for those engines that allow you to jumper certain connections to vary the timing configuration.
Old 05-05-2022, 08:17 PM   #43
Thumper   Thumper is online now
Why 4 degrees?
If 4 degrees causes kickback, why not try 3 degrees, or 2 degrees? It would still improve performance.
I know, the key isn't available, but a less radical key could be ground on the protruding side on a 4 degree key. You can then shim the shim on the side that is recessed with sheet metal. Viola, 2.7 degrees, or 3.1 degrees. Additional performance is great, but 4 degrees is arbitrary!
Old 05-15-2022, 04:03 PM   #44
TORKER   TORKER is offline
I'm having a hard time finding the 4 degree key. Anybody knows who has it in stock? Didn't see it at Henner Motorsports today.
Thanks in advance.
TORKER.
Old 05-15-2022, 05:43 PM   #45
0
Thanks in advance.
TORKER.
There are currently none to be had anywhere. Likely a shortage issue. Who knows when we will get more again.
