Old 03-12-2007, 10:17 AM   #31
Originally Posted by ejcycles
Hey guys
I already have a A. Lifan 200 engine apart that had a Major Vibration problem. I'm already in the process of checking on the clutch plates.
Bruce
Are you cross referencing an xr200 clutch? It would be great to know it this is a direct drop in replacement.
Jason
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
Old 03-12-2007, 08:59 PM   #32
FMYStreetRacer   FMYStreetRacer is offline
well i fixed it. i only ran it for a minute. i forgot my camera at home so all the pics i took were with my cell phone. i e-mailed them to myself but the service is acting up. after i eat dinner i'll hook the cable up to the phone and upload them like that. i'll post pics and tell you guys what i did.
Roketa DB-07a
HID Headlight
Old 03-12-2007, 10:51 PM   #33
ok here's what i did:
i took the clutch cover off. once you get it off there is a plate that is bolted to the outside of the clutch basket. it is the release and also has the springs attached to it. i loosend the four bolts that held that together. once you take that off you can remove the clutch springs. i took some washers and drilled them out to be bigger that the posts that the springs went around. the first set i tried to use that were in our bolts bin at work were too large around. they need to fit in the cover that i removed so that the spring won't sit crooked. so i searched around and remembered that i saved all the extra bolts and washers from the assembly of my bike. what do you know, i found eight of them and they were the right size around but the center hole was super small. i drilled out the centers and deburred them. i decided to use two washers. i couldn't have used a 3rd. two washers made the springs almost complletly compressed. it worked out really well from what i can tell for the whole 2 clutch dumps i did.
anyways here's the pics.
spring assembly removed.
clutch disks. 5 disks just like a xr200 from what i can tell.
what is the hell is a plastic gear doing is here? someone please tell me what that is for.
the disks
this is for Bruce, i know we talked about you trying to see if the xr springs are the same.
this is the plate that holds the springs on. see where the face of the spring sits? the washers need to sit there, can't be bigger.
my nastey job of drilling out the holes. i had to do it by hand with a air drill. they look like shit but hey they work.
washers installed before everything is aligned and tightend down.
tightend down
[img]http://img84.imageshack.us/img84/2156/image154eq5.jpg[img]
tightend down side
i'm going to most likely take the bike to work tomorrow. i'll be sure to post up how much better the clutch is.
Roketa DB-07a
HID Headlight
Old 03-12-2007, 11:06 PM   #34
ambassador   ambassador is offline
Not much different from my XR except for the plastic gear, gotta be a part of the starter, maybe oil throw???
06 Lifan 200 GY-5
Old 03-12-2007, 11:08 PM   #35
starter is on top. guy at my work said maybe it's for crank case vent. all i know is that i don't like that crap there at all.
Roketa DB-07a
HID Headlight
Old 03-13-2007, 12:47 AM   #36
liverchip   liverchip is offline
Send a message via MSN to liverchip
Maybe oil pump?
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 03-13-2007, 01:16 AM   #37
Probably a dumb question, but were you guys looking for a supplier for clutches? I found mine TSM 200 (grey market Lifan pushrod) for 42$. No need for it as of yet, but I believe in being proactive. Now if only I could find brake pads.
Tusk bar risers
--mods---
15/40 sprockets
UNI Pod Filter
FMF Powercore pipe
Uni Pod Filter
Old 03-13-2007, 09:04 AM   #38
FMY,
Great job, I can't wait to hear how it works out for you!
Can you give the inner (i.d.) and outer(o.d.) diameter of the final washers. I may be able to find some that are that size that can be bought and I'll post them in the parts thread. Otherwise I will just do what you did.
Also, what was your final thickness with the two washers? I may just get Dad to machine the exact size washer (spacer) as one unit.
Thanks for you help.
Jason
Old 03-13-2007, 10:13 AM   #39
cycleway4   cycleway4 is offline
hi...yes, plastic gear drives the oil pump..........this is a typical set-up[for that purpose]
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 03-13-2007, 12:26 PM   #40
Originally Posted by fatboy250
FMY,
Jason
the inner hole is 15/32 and the outter i didn't measure, just figure as wide as the spring..... 18.5 mm. let me see if i can dig up two more washers and i'll mic them real quick. na, i jusy looked and i can't find even one. guess Roketa just knew i would need them. if i ever take anything else out that uses that washer i'll mic it.
i drove the bike in today and just took it to lunch, so farso good. it feels really good now.
Roketa DB-07a
HID Headlight
Old 03-13-2007, 03:47 PM   #41
The 15/32" comes out to just under 12mm. So, it sounds like a 12mm i.d. and 19mm o.d., or would 19mm be more than the surface area you had to work with on the plate? We're talking .728" (18.5mm) versus .748" (19mm). Thanks for the info.
Jason
Old 03-13-2007, 07:50 PM   #42
the half milimeter might be too much.
Roketa DB-07a
HID Headlight
Old 03-13-2007, 11:00 PM   #43
Roketarider   Roketarider is offline
I might be attempting this tomorrow, as my clutch is slipping bad in pretty much all gears.
Roketa DB-07A 200cc
Old 03-13-2007, 11:57 PM   #44
Streetracer, Is your motor the OHC or pushrod?
Tusk bar risers
--mods---
15/40 sprockets
UNI Pod Filter
FMF Powercore pipe
Uni Pod Filter
Old 03-14-2007, 12:31 AM   #45
ohc
Roketa DB-07a
HID Headlight
