#31 |
Spoke to the Guys down in PIT Motors LTD and they will be doing some live load testing cause I was thinking of taking the 15/42 to a 15/38
Will keep you guys posted |
#32 |
Gardo,
That 15/38 would be the same as my 13/33 which might be a little high for a young guy like you. Anyway it's easy enough to change the rear sprocket with the right o-ring pliers. Be nice to see the dyno power curve from PIT. I might take mine over to my dyno guy. |
#33 |
Barnone - I dont understand your meaning of "too high" could you explain please
thx |
#34 |
I'm running 15-42 on my 167fmm and it will stay pinned at 8k rpm+ on all but the steepest hill. I'm going to a 16-42 and I'm sure it will pull it fine as this motor is all low end. This is on a an upright dualsport so I'm sure you should be fine.
Saga 250 Enduro |
#35 | |
A 15/42 combo is a 2.80:1 ratio, and a 15/38 combo is a 2.53:1 ratio. The 2.53:1 ratio is higher (which is lower numerically), and that translates to more top end speed and less low end acceleration. The reverse is true for the 2.80:1 ratio.
#36 |
W&G,
Good explain as Darrell Waltrip 0f NASCAR fame says. |
#37 | |
Thanks for the numbers and confirmation of my suspected low end power of the 167FMM engine. At least that how it feels to my butt dyno. |
#38 |
Yea makes me wish there were hotter cams for this engine as I'm sure
there would be a pony or 2 to be had there.
Saga 250 Enduro |
#39 |
Thanks WG that makes a bit more sense. i figure that i rode a Heist with the stock 15/42 I will play with it stock for now and play with the numbers some with the guys from PIT
#40 |
Easy thing to try would be to swap a 16 or 17 sprocket on the front.
#41 | |
