05-22-2011, 04:38 PM | #31 |
couldn't locate my dremell to clean up the edges but that can be another project.
got it all bolted in place took this into this one ratchet strap and this should work fine. and I did get to test the winch today....took it out to the back yard , tied a rope around a tree, fed out some line, put the quad in reverse with the brake on and winched.......it dragged me and the bike accross the back yard all the way to the tree....mind you that seems to be quite taxing on the battery but the quad was charging and is now on a charger so it should be good to go.
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div> |
05-23-2011, 10:56 AM | #32 |
Most likely you won't be winching with the brake on and in reverse either.
05-23-2011, 11:26 AM | #33 | |
lol no your right but was the best way to test it in the back yard :wink:
05-23-2011, 02:30 PM | #34 |
Was that with or without a snatch block?
05-23-2011, 06:07 PM | #35 | |
no snatch block just a rope around the tree and the winch hooked to the rope
05-24-2011, 12:42 AM | #36 |
Then those are excellent results. A snatch block will double your pulling power.
