#421 | |
Do you have the link to the 300cc kit?
#422 |
I sent you a reply in your messages
#423 |
So, got my headlight bucket in at least. Still waiting on the brackets and I need to order the projector and related bits still, so it will be a bit longer until I can complete it, but this is what it will look like.
Thankfully, this bigger style of bucket houses the entire projector housing assembly rather well. Has a little room to spare on the inside. As somebody else put it, looks a bit like something out of Star Wars lol. ![]() ![]() The spaces between the ribs being open is making me consider putting a 12v strip of LEDs around the inside and wiring that in to the DRL light, which in typical Hawk fashion only turns on with the headlight.
#424 |
That will be a nice upgrade.
#425 | |
I am undecided on what to do with my drl circuit yet. I may add a demon eye light to the projector and rewire it as you did.
#427 |
That monster is LED lol. I could do before and after of my Hawk with it's current plug and play LED like most of us have vs. This guy. It would be hard to do it any real justice without being able to fix/lock the exposure though.
#428 |
Three attempts over several months and finally I got my hands on one. Even came with a steel head gasket.
![]() So, the only catch to the CG300 cylinder is that the outer diameter of the sleeve at the engine cases is a tiny bit too big, so some sort of machining needs to be done. Roughly about half a mm needs to be removed (I will measure when I can) from the outside of the sleeve to match a CG250 cylinder, so instead of machining the cases I think I am going to do it the "wrong" way and remove from the outside of the sleeve. I don't think a couple thousandths are going to hurt anything. I also don't plan on installing this anytime soon anyway as I am considering changing to a different cam style with some added lift, which will means I need to have more head work done to recess the valve seats for valve clearance reasons. So this is likely going to be a winter project.
#429 |
I wonder what the compression ratio will end up at. It's a much bigger displacement with a flat top piston under the same cc head.
#430 | |
A part of me is tempted to, assuming my measurements confirm the above speculation, simply install the cylinder with my current head and cam setup. A part of me is curious to see if my already ridiculous midrange and low end torque will become the ultimate in tractor pulling power lol.
#431 |
If you cc the head, mock up the assembly for deck height, etc and find the CR is gonna be too high (who wants to run 100+ octane in a daily playbike?) you might be able to find a shop that works on modded two strokes and have the squish ring area machined some. The 4 degree ignition key way may have to go too. But for the extra displacement it should be worth it.
What will the actual displacement work out to?
#432 | |
Actual displacement would be 250.149cc (65mm stroke x 70mm bore). So it will be an actual 250cc lol.
#433 |
It's still a 9% increase in displacement which on a head flow restricted motor like the CG may not add any hp, but it will pump up the torque.
On the BB kits for the KTM rfs motors, some of the guys complain they lost a little rpm over rev, but after you adjust your riding style it's a win. Of course we used to have a bunch of cams we could use to make up for the overrev if we wanted. The cg cams are a little more limited in selection. I cant wait to see how it works.
#434 | |
Yeah the "right" way to do it, is machining the case. To be honest, is not worth doing it. A modded Hawk like the way dan is, can already beat a stock "300"
The picture above is the "GATO CG300" it has the same top speed than a 230 but it's more torquey About the cams you would be surprised about all the differents profiles they made for the CG. To be point of being ridiculous |
#435 |
I ordered one of the kits but wont make any efforts to install it until this summer when it's too hot to ride here.
For now I'm messing with suspension.
