Old 03-31-2018, 02:11 PM   #421
ChondaChondaChonda   ChondaChondaChonda is offline
ChondaChondaChonda's Avatar
The bump start backup has never failed me.
Plus, we always carry a little "jumper cable" that plugs bike to bike on the trickle charge circuit.
Old 04-03-2018, 09:47 PM   #422
Clutch issue ramblings'
I promised way back in this thread to talk more about my clutch "failure" on our Day 1 TOI attempt.(successful attempt)
Recently the problem has hit a few other LXR250s, so I wanted to present my theory... it's just a theory and we may find that I am totally wrong on this. I accept that there are many, many smarter folks than I about the inner workings of motosickles. Hopefully they will chime in.
I made this little video in hopes that it will help someone "see" what I'm talking about; it was thrown together quickly and I should have used a tripod, but here goes:
Here are a few pictures of the clutch parts in play:
Last edited by ChondaChondaChonda; 04-04-2018 at 09:35 AM. Reason: add successful "attempt"
Old 04-04-2018, 09:31 AM   #423
chadzu   chadzu is offline
chadzu's Avatar
Attempt? Attempt!
You my friend laid waste to the TOI on that BA China bike.
Old 04-04-2018, 03:55 PM   #424
I think you are on the right path with the clutch issue. If that rod is just a hair too long, it will take up any slack when it expands thermally and could be putting constant pressure on that thrust bearing, and thus the clutch. It's no different than valve lash on a solid lifter valvetrain system.
I almost wonder if there is a spec for the gap between the two rods that can be looked up or provided by Pitster Pro. It wouldn't have to be much, maybe 2 thousandths or so.
Old 04-04-2018, 05:46 PM   #425
I've not heard of this being an issue with the RX3. Did I miss something or is this just on the PP's? Odd, same basic motor.
Old 04-04-2018, 05:55 PM   #426
I would imagine it's possible on any NC250. Don't follow RX3 stuff enough to know if the clutch has left anybody stranded.
If it happens, they should know that it's pretty easy to lay the bike on it's side and pop the clutch cover off; 5 x8mm screws. Then pull the 6 x8mm screws and springs to remove the pressure plate; removing the shim will temporarily get you going again.
These clutches are quite large and robust for the power output of the motor. I know when this happened to mine I had been flogging the bike hard and it was a long steep climb. It sounds like a similar situation with the recent event.
My hunch is it only affects a tiny percent of the NC250s out there.
Old 04-04-2018, 05:59 PM   #427
You are right, it wouldn't take much. And we have 6 machined surfaces for tolerances to vary.
It would be hard to measure the clearance anywhere in this setup. I just don't see anywhere that a guy could get a feeler gauge in, except the clutch plates... maybe a spec when the clutch is fully pulled in??
Old 04-13-2018, 05:55 PM   #428
Thumbs Up Otom protective parts added
I wanted to see what these plastic case protectors were all about. They are quite a tough plastic and should add some good protection, but I can't see them staying clean for very long. Also a brake res shield.
The flywheel side cover wasn't going to fit until I modified the top hole. There must be different versions of the NC250 that don't have the crankcase vent hose there.
Old 04-13-2018, 05:57 PM   #429
Radiator cap with temperature gauge
And an Ebay aluminum clevis:
Old 04-14-2018, 08:51 PM   #430
Thumbs Up Wet wiegh in...
So, after getting the new graphics on and all the rest of the bike bolted together it was time to see how many lbs it was at. 276.0 lbs. Full of oil, coolant, and with a bit of gas in it (maybe 1 gal?). Ready to ride weight.
Took the bike for a spin. First time since I put the lowering spacer in. Feels like it needs more pre-load. Definitely need to get my sag set correctly.
Old 04-14-2018, 09:44 PM   #431
Where did you find those plastic covers? Do you have a link for the rad cap? Love the scale!
Old 04-15-2018, 10:36 AM   #432
Plastic covers:
https://item.taobao.com/item.htm?id=561652129834
Rad cap:
https://item.taobao.com/item.htm?id=562783718351
Old 04-15-2018, 12:17 PM   #433
Ariel Red Hunter's Avatar
Plastigage....ARH
Old 04-16-2018, 12:29 PM   #434
Looks awesome.... Not a soul who sees you out on the trail is going to have any idea what you're riding!
Old 04-22-2018, 07:04 PM   #435
efi, fuel injection, lxr250, pitster
