#406 | |
Look at the photos I posted of the rear wheel and tell me how the wheel can become misaligned if properly adjusted and tightened? Certainly the wheel could become misaligned if damaged in a crash or if the owner messed up the parts. I have two other motorcycles (and many more in the past) with the same type rear wheel attachment and never have a problem with the wheel getting out of alignment. EDIT. Do remember owning a CB125 back in 1974 but don't remember having rear wheel alignment problems. Last edited by Barnone; 05-18-2020 at 11:00 AM. |
#407 |
Did find a reference to clean the centrifugal oil filter on the CG125 every 7200 miles (12,000 km) so am not going to worry about it for a while.
#408 | |
#409 |
I was just saying after the first 1k miles because with the reputation of Chinese machining, it's better to be safe than sorry. It's just cheap insurance.
#410 |
I have had very good luck with my Chinese bikes over the years with no engine problems. I keep magnetic drain plugs in all my bikes except the DF and get very little or no metal on them. Can't find a magnetic drain plug for the DF.
#411 |
The slinger will largely do the same thing, but removes particles centrifugally, even non-ferrous particles. I'm not saying Chinese stuff is always/usually bad, it's more that surface finish isn't as fine equivalent Japanese stuff, which leads to more particles; Honda wouldn't have included it in the original design if it wasn't needed. You could probably get a thread gauge on the drain plug and find one that will work, or else cut the threads to something that'll work.
#413 | |
Remember that was an idea used a long time ago before oil filters as we know them today. I am very familiar with magnetic drain plugs as I have been using them for years in my tractors, trucks, autos,motorcycles,etc. The problem with finding one for the DF's engine is that the only oil drain is the large fitting that cover the area of the filter screen. There is no other drain plug which is fine since you can drain the oil and clean the filter just by removing the one bolt. I might have found one on Ebay but am waiting for a reply from the seller. Have some other ideas but will wait on the Ebay seller. Or something like this small enough to fit there underneath the spring. https://www.amazon.com/Motion-Pro-Oi.../dp/B007GM1JKA |
#414 |
Yes, the slinger is an old idea, though it's usually based in the crankshaft itself (and if I remember correctly, it only cleans what it whips up from the crankcase), while Honda's idea is a little different in that it driven by the crank, with the oil it receives pushed through by the pump. I can post up a picture of the oil circulation circuit from Honda if you're interested.
#415 | |
#416 |
Has anyone ordered their bike from Redbox Powersports? If so how long did it take to get your bill of sale. I still haven't got mine and it seems impossible to contact anyone over there.
#417 |
I've read some bad review on them. Hope you don't have any issues getting it.
#418 |
Hey guys guess what, I found a 6 speed gear set near for the Chinese version of the cb250. Idk if it will work, I hope it does fit the cb250 Chinese engine.
https://m.alibaba.com/product/608059..._140x140xz.jpg |
#419 |
There's a chance it'll work, but you'll have to get rid of the kickstarter at the very least, if it will work. I'm fairly certain no one has taken the chance on a 6-speed gear set on this forum, but swapping a transmission is a complicated affair, since you're relatively new to wrenching, I'd get an extra motor before attempting this, so you don't turn your bike into an expensive paperweight. You'd also need a new shift drum, shifter star, and shift forks, along with everything to split the cases, too.
#420 | |
