02-08-2017, 01:50 AM | #391 |
02-08-2017, 07:48 AM | #392 |
check the valve lash to make sure it is ok. My bike was hard to start until i did that.
02-08-2017, 07:53 AM | #393 |
Skurdy,
That screw is only for adjusting Idle Speed. If you remove the carburetor and flip it over you will see a black plastic plug. I used a drywall screw and drilled it into it to remove it. That's were your idle mixture screw is. Close it all the way and back it out to 1 1/2 turns to start with. That worked perfect on mine. Also take the needle and shim it with 2 thin washers. This will help on cold starts. Order some jets for it and change out the main jet to a 110 if you have the stock exhaust. You can use a hack saw to cut slots in the screws to remove the bowl. Motocheez has a good YouTube video on how to do it. Also your shocks should be almost flush with the top of the triple tree.
02-08-2017, 08:57 AM | #394 | |
02-10-2017, 12:42 AM | #395 | |
02-10-2017, 12:44 AM | #396 |
No Clue where that's even Located?!
02-10-2017, 08:04 AM | #398 |
Yes it does have a master link. The Mikuni will come with stock jets. I'm not the exact size it comes with but I know you will have to change out to a larger jet.
02-10-2017, 08:06 AM | #399 |
I 2nd that. there are a few youtube videos on tuning the carb, valve adjustment and pretty much anything else you need to know.
02-10-2017, 09:23 AM | #400 |
You know it is an overhead valve engine, right? So the valves and rocker arms are under that valve cover on the very top of the engine. Adjusting valve lash means first measuring, then adjusting the clearance between the rocker arm and the valve. There are two valves. One lets the air/fuel mixture in to the cylinder, and the other lets the super heated air, along with the remains of the burnt fuel, out of the engine. That valve is the front one in the engine. Called the exhaust valve. The other one is called the intake valve. Motocheeze has a video on youtube showing how to do this. I reccomend you watch that video several times until you "get it".
02-10-2017, 10:06 AM | #401 |
Carburetor Magic
Hey, you guys that remember me extolling the virtues of the Mikuni VM26 with a starting circuit instead of a butterfly choke, but tripped over your chain-drive-wallet, here's a real deal, as long as they last. https://www. amazon.com/dp/BOOBXLOQSM Such a deal.
02-10-2017, 12:32 PM | #402 |
new parts!
hi everyone! Just wanted to say that everyone on here is full of great knowledge and thank you for sharing all of it. I ordered sprockets and chains, carbs, a rear shock, and a feeler gage for the hawks I bought for the wife and myself based on what Iv read on the different forums on this page. Parts are supposed to be arriving as early as Tuesday! Ill be putting them on as I get them and ill finally get to adjust the valves. I have almost 1000 miles on my bike and my wife has 300 on hers. I have watched the Motocheese videos on YouTube and can't wait to get hands on with the Hawks. I'm sure ill have questions that have probably been asked and answered on here several times so please be patient with me haha... Again thanks to all of you for your infinite wisdom!
02-10-2017, 09:04 PM | #403 | |
02-11-2017, 11:20 AM | #404 |
Top end horsepower
One of the chief advantages of the engine used in the Hawk (and others) is the absolutely rigid and stiff crankcases. You would be amazed how much engine horspower is eaten up by panting engine cases. This is one of the many things that let engines get horsepower to the ground. Non-rigid crankcases absorb horsepower by getting slightly out of true, and then putting loads on the main bearings that they were never designed to deal with. When the main bearings do not run absolutely true to the crankshaft, two primary things happen. 1) Overloading one end or the other of the main bearings, especially roller bearings. This leads to short bearing life, and, by running out of true, increased friction. 2) And very serious, putting bending loads on the crankshaft. And worse yet "panting" means not a steady off center load, but repeating the whole bending process every other revolution, during the power stroke, and then whipping back to where it was designed to be for the next two strokes. Now crankshafts are made of very high tensile steel, and then hardend where the bearings run. The rod bearing, and the two or three main bearings. High tensile steel, hardened, is pretty well bullet proof as long as the crank cases are rigid. But put bending loads on them and crank failure is inevitable.
02-11-2017, 12:21 PM | #405 |
And some more of the story
It took about 25 years before it perculated through the engineering world how important rigid crankcases were. I would not be at all surprised to learn that this knowledge came with the introduction of the dynomometer metheod of taking torque readings. The Prony Brake metheod led to flash readings because you couldn't cool them effectively. But a dynomometer can be cooled, and so allowed long dyno runs. When an engine is pulled down after a long dyno run, one can measure where wear is occuring in the engine. I would bet that the bearing wear after 100 hours at 85% of full power came as a real wake-up call to those engineers. There was no excuse for the accelerated bearing wear. They used to just shrug it off as dirty oil, or too much spark advance, or whatever. But no way to shrug off engine wear on a dynomometer in a lab with controlled conditions.
