Old 08-01-2015, 01:36 AM   #3991
CSCDude   CSCDude is offline
CSCDude's Avatar
Joe
www.ExhaustNotes.us
Old 08-01-2015, 04:49 PM   #3992
I just got back from a 3-day trip to the Great Salt Lake. I will post a complete ride report later, but here are a few photographs until then.
Old 08-01-2015, 09:35 PM   #3993
rjmorel   rjmorel is offline
rjmorel's Avatar
Looking forward to ride report Spuds. So how fast did you get it going on the flats? Break any records? Got to ask why no LH pannier? rj
Live Zong, and Prosper
Old 08-02-2015, 01:11 AM   #3994
I'm betting I broke all records for the Zongshen RX3, since I was probably first across the flats.
I like trying different luggage configurations. The right pannier is good for holding clothing layers, and small packages. It is nice always to have some dry, lockable storage on the bike. Drive chain maintenance and washing are easier without the left side pannier, and the bike is lighter. The travel trunk unlocks easily from the luggage rack, so I can add or subtract it as I please. Since I stayed in a motel, I didn't need the extra storage for this trip.
Old 08-07-2015, 10:36 AM   #3995
Here are several videos from AKT, which is importing the Zongshen RX3 to Columbia. Two riders from AKT acccompanied the 5,000-mile, CSC tour of the western United States.
Old 08-07-2015, 10:49 AM   #3996
Old 08-07-2015, 10:59 AM   #3997
The Zongshen RX3 is being imported to Argentina, and sold as the Corven Triax 250 Touring.
http://www.corvenmotos.com/motos/triax-250-touring
Old 08-07-2015, 11:01 AM   #3998
Old 08-07-2015, 03:09 PM   #3999
I just received an email from CSC reporting the 13T C/S sprockets have arrived. If you ride at high altitudes, or you just want better acceleration and low speed handling, I strongly encourage you to at least experiment with the 13T C/S sprocket. CSC is selling the 13T C/S sprockets for $12.95.
Old 08-07-2015, 06:44 PM   #4000
detours   detours is offline
detours's Avatar
Sweet! I just ordered one!
Red 5 standing by!
2014 Ural Patrol
Old 08-07-2015, 10:31 PM   #4001
Huck369   Huck369 is offline
Huck369's Avatar
I also got the email, and called and ordered one.....and a t-shirt....and a front hub(to lace to a spare 19" aluminum rim I have laying around)
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 08-08-2015, 09:27 AM   #4002
DanKearney   DanKearney is offline
Can the 13 tooth CS sprocket be swapped in without changing the chain length?
Cheers,
Dan K.
Dan Kearney - Black Hawk, Colorado, USA
Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ."
Old 08-08-2015, 12:21 PM   #4003
Cheers,
Dan K.
Yes, the 13T C/S sprocket fits the stock, 110-link drive chain. However, you are going to need to tighten some slack from the drive chain after you install the 13T sprocket.
Old 08-08-2015, 01:04 PM   #4004
3banger   3banger is offline
3banger's Avatar
Getting High Smoking Clutch in CO on Imogene Pass!
This tail starts with ride down south to Ouray CO to give the little Zong a real work out with a planned climb over Imogene Pass to Telluride. Climbed to the summit of 13,114' on the girlfriends XT250 just about a year ago with out much difficulty so I figured it couldn't be that much of challenge on then RX3 with 7+ more HP and only a little more weight.
Stopped in Ridgeway CO (home of the Grammy!) at CimarronEric's cool little coffee and book store. Over a fine Ethiopian blend we discussed the difficulties of getting up the steeper sections of Imogene Pass with the tall gearing on the RX. After some delicious but potent brew I headed south determined not to be denied the Summit
Through Ouray and up to Lower Camp Bird is really a none issue for the little 250 and its stock gearing. Above this point is were things get interesting. It turns to a full 4x4 Jeep road with a few pitches that are challenging to most stock four wheel drive vehicles. This is were the overly caffeinated charge for Imogen Summit glory and real clutch abuse begin. I was deterrent to power up all of the steepest assents with enough speed not to stall the engine. As grades increased my technique moved from a little clutch slipping here and there to full throttle pinned in first gear and modulating the clutch to keep it just shy of redline. This let me get max power to the ground at speeds less then 10 mph while keeping the little 250 on full boil. The down side of this is massive amounts of friction generated heat being dumped to the clutch pack.
The clutch held in there admirably and I made it a little less then a mile from the summit. The clutch felt like it was giving good drive and modulation right up until the end. I needed a little push to clear the section in the photo below with the jeep. With the help of a friendly quad rider pushing the rear rack and my self walking alongside slightly slipping the clutch in first we walked right up this section. Eric I'll admit this section was a bit of a challenge on the RX and I had a few minors tip overs trying it with out assistance. After this there is short down hill crossing a little creek drainage and then pretty much the final pitch to the summit and this is were any mechanical connection between the little 250 engine that could the and the rear wheel just went away. When the clutch was done it was done! Gravity assist down hill drive was the only way this bike was getting off the mountain.
So in your mind when you climbing a big ass hill like Imogene it's got be down hill all the way back? Well that's what I thought when I turned around and how wrong I was! So I have to give a big thanks to the mystery side by siders who helped tow me up every little incline I couldn't maintain enough speed to coast over. Also the RX has great little tow point right under the front fender where engine guards connect. After multiple coast, tow repeats I finally rolled into Ouray later in the afternoon. My girlfriend and friends were in Ouray for training runs on the pass; the big Imogene run is in early September. So they gave us a ride home and then we made late night return trip to fetch the Zong.
The next day I gave the bike a quick rinse drained the foulest smelling oil I've very had the pleasure to sample and pulled the clutch. It's actually quite easy on this bike. The friction material on the two inner most fiber plates was basically gone and the corresponding steals were throughly cooked. I ordered a whole new clutch pack from CSC for a very reasonable 74 bucks. I contemplated just replacing the fibers and then giving the steels a good sanding or bead blasting but with them only being $2.80 a piece there is no reason not to replace them. One of the real values of the moto is the very reasonable cost of parts and that CSC is stocking them all! Also just ordered the 13t front sprocket, this will help but I still feel Imogene will be a challenge on the RX. Really first gear needs to be geared to redline at about 10mph to really make technical climbs a little more doable.
My new clutch bits arrived but I haven't really been able to complete the job. The following weekend I gave my left collarbone a titanium plate up grade running the down hill MTB park in Steamboat CO. Yep over the bars at speed and fractured the left clavicle, bruised right ribs and a nasty friction burn to the shin from one of my tires. Also took out a front spoke with the chin guard on my full face helmet. So it will be a month or more before I'm back on two wheels. But hopefully I'll be recovered enough to start fixing things. Right now the list is a KTM 200 with a no compression, RX3 with a smoked clutch and a Transition Covert MTB that need tires and few front wheel spokes; about par for me near the end of any summer...
Old 08-08-2015, 01:11 PM   #4005
Thanks for posting the ride report from Imogene Pass. I hope you heal quickly.
