Old 07-12-2015, 04:11 PM   #3856
Add Turkey to the list of countries selling the Zongshen RX3. The bike is being rebadged the Mondial RX3i Evo in Turkey.
http://mondialmotor.com.tr/model/enduro/rx3i-evo
Old 07-12-2015, 04:29 PM   #3857
katflap   katflap is offline
katflap's Avatar
Nice find spud,
I notice in one of the smaller images under the main bike pic.
It shows the throttle body upside down
Old 07-12-2015, 07:07 PM   #3858
Originally Posted by katflap View Post
Nice find spud,
That is how the throttle body is mounted on my U.S. bike, Kat.
Old 07-13-2015, 01:06 AM   #3859
detours   detours is offline
detours's Avatar
Detours,
Thanks for posting your impressions, and welcome to The Cult of The Zong.
Thanks, glad to be here! I've wanted to join ever since I found out about this bike.
Red 5 standing by!
2014 Ural Patrol
Old 07-13-2015, 06:14 AM   #3860
katflap's Avatar
Thanks for letting me know spud
This had me head scratching for a while but I think I have got to the bottom of it.
It seems the early Honley RX3 had the throttle body like this.
You can see the cast lug on the throttle body located in the cut out slot of the rubber manifold bit. (arrowed).
At some point they must of decided it was better the other way up.
Out with the spanners I go to turn it around.
Unfortunately my throttle cable wasn't long enough to reach
Fortunately I had ordered a spare from Taobao which was longer
Harmony restored
Old 07-13-2015, 11:14 AM   #3861
Aside from the cast lug, I presume there is no upside-down for a dry-flow throttle body. It's only moving air.
Old 07-13-2015, 12:14 PM   #3862
Thanks for letting me know spud ...
Harmony restored
Old 07-13-2015, 01:07 PM   #3863
I weigh over 200 pounds, and I ride at elevations of 4,400 to 10,400 feet above sea level. Yesterday I replaced my 14T C/S sprocket with a 13T C/S sprocket, and I like the lower gearing very much. The engine is far less likely to stall while starting out in first gear, and the engine holds its power better going up long inclines above 5,000 feet of elevation. I like the response of the engine better in all gears, and at all rpms. If you are a heavier rider, or you ride at elevations over 5,000 feet, I suggest you might like the 13T C/S sprocket better than the stock, 14T C/S sprocket.
Old 07-13-2015, 03:53 PM   #3864
detours's Avatar
Registered my bike this morning and got several compliments on the bike in the parking lot. No one could believe when I told them I got the early bird price of $2895. And they all said it was cheap at $3495. I told everyone to check out CSC online.
Red 5 standing by!
2014 Ural Patrol
Old 07-13-2015, 06:57 PM   #3865
Good for you. I also get many compliments regarding my RX3.
Old 07-13-2015, 10:44 PM   #3866
MattyBoy1976   MattyBoy1976 is offline
MattyBoy1976's Avatar
Hey Spud (and anyone else who might offer advice), forgive a rookie question, but does lowering the gearing affect the top end and cruising speed? I ask because I just added a slightly smaller rear sprocket to my TW200 in order to lower my RPMs at highway speed, and get a little less buzzing. It worked (mostly-I may get an even smaller sprocket). When I get my RX3, I too will be riding a pretty large range of elevations (5400-12,000 feet, likely), but I have to do some highway riding to get to the good stuff.
2009 TW200 (first bike ever, sold it!);2015 RX3 Cyclone in blue (first "big kid" bike ) with 13T front sprocket, 19" front wheel, center stand, heated grips, LED aux lights, CSC skid plate
Old 07-14-2015, 12:32 AM   #3867
Jay In Milpitas's Avatar
Matty, short answer is "Yes."
Dropping the front sprocket one tooth will cause the engine to rev higher at the same speed for the stock 14 tooth.
In other words, since the engine can easily pull redline with stock gearing, the lower gearing will allow it to reach peak rpm quicker although mph will be lower.
It's a compromise you will have to decide on.
Jay.
Old 07-14-2015, 12:55 AM   #3868
Jay.
In theory, Jay's short answer is correct. However, in this instance, I can actually go faster with the smaller, 13T C/S sprocket. This might not hold true for riders weighing 150 pounds, and living in Florida, Indiana, Illinois, et cetera. However, riding at high elevations, the smaller, 13T sprocket holds its speed much better while climbing long inclines above 5,000 feet in elevation. Therefore, I don't have shift as much, and I actually end up going faster.
Also, the bike doesn't want to stall while pulling away from stop lights in first gear. The bike accelerates better, and preforms better in all gears at all rpms. In my instance I can't find a single downside for switching to the smaller, 13T C/S sprocket. If you weight little, travel light, and live in the flatlands at sea level, you might want to keep the stock, 14T C/S sprocket. However, if you weigh more than 200 pounds, carry stuff in the luggage, carry a passenger, and/or regularly ride about 5,000 feet in elevation, I highly recommend the smaller, 13T C/S sprocket. Once you make the change, you will never want to go back.
Old 07-14-2015, 01:00 AM   #3869
I bought my 13T C/S sprocket at Taobao while I was placing an order for other items. I called CSC today, and talked to Ryan. CSC only has the 14T C/S sprocket in stock at this time. I strongly encouraged them to also acquire the 13T C/S sprocket.
Old 07-14-2015, 05:32 AM   #3870
katflap's Avatar
Yeah, it shouldn't really make any difference.
I just wonder why Zongshen bothered especially as this required fitting a longer throttle cable.
