07-12-2022, 01:11 PM | #361 |
Anyone know the listed weight capacity for the X? The regular Templar is 440, which I was surprised by how high that was.
07-12-2022, 01:24 PM | #362 |
I copied and pasted specs into a word document and saved it before they ran out of the X models. It's at home. I will take a look tonight.
07-12-2022, 01:24 PM | #363 |
Thanks.. you've been super helpful!
07-12-2022, 04:09 PM | #364 |
This is what I copied from the website before they ran out of stock. On the bill of Sale, and on my post in the photos and videos section, the model number is X7-CB250F. And yes, I see I paid $1849.95 plus $299.95 shipping, for total of $2,149.90
My MO sales tax and registration/title/plate fees came to about $200. So about $2250 total. |
07-12-2022, 04:35 PM | #365 | |
07-12-2022, 05:24 PM | #367 |
Usually, the MCO has the G.V.W.R (Gross Vehicle Weight Rating) which is the total weight including max payload. It's needed for most DMVs and some state inspections.
07-12-2022, 06:04 PM | #368 | |
I owned a Suzuki DL1000 Vstrom. It was torquey and FUN to drive, but not exactly at home anywhere but the road and a nice hardpack logger road! The Honda African twin is an extreme example. There are videos on youtube of the need for TWO people to right the thing on the trail A reasonable luggage adaption could work well on the X. But keep in mind that tall bikes put that weight in a position that you end up lifting it all if you fall over! |
07-12-2022, 07:41 PM | #369 | |
07-13-2022, 09:45 AM | #370 | |
I could definitely use a stiffer spring in the back but it’s nothing that really impedes on the bike. I can tell the hot weather really takes some power out of the girl but I still too Out at about 65, cooler weather was around 70.
2022 X-Pro Templar X 250 “Rocinante” 2022 X-Pro Bolt 125cc “Dapple” 2022 Royal Enfield Interceptor 650 “Traveller” 2023 Royal Enfield Classic 350 “Trigger” |
07-13-2022, 05:48 PM | #371 | |
Which rear sprocket did you buy?
07-13-2022, 11:33 PM | #372 |
The 42 tooth from Amazon is what I like best here's a link.
JT Sprockets JTR210.42 42T Steel Rear Sprocket , black https://a.co/d/cXLPLH4 I believe you might be able to run a 38T in the rear now with the 14 front sprocket. But 1st gear would be to quick for trails in my opinion. A link to the 38T I used.. JT Sprockets JTR897.38 38T Steel Rear Sprocket black 38 Tooth 1 https://a.co/d/8U0whlY |
07-14-2022, 06:42 AM | #373 |
PSM is now saying 2 months before X's back in stock. Really sucks!
07-14-2022, 07:20 AM | #374 | |
What I found is still very impressive and depending on your style of riding if may fit better. It appears to be a Wuyi Zuma built bike. The same as the TemplarX. Being shorter appeals to me for tight trails especially with the torque from the ZS172FMM3-A motor. Here is the link to what I believe is the manufacturer. Was correct for the TemplarX. I believe the model is a K5 or K7. https://zuumav.m.en.alibaba.com/ |
07-14-2022, 11:24 AM | #375 | |
The K7 (frame?) also comes with a liquid cooled 300cc engine (K7-NC300). It is a four valve 6 speed engine. NC appears to be the liquid cooled notation-there is an NC250 as well. I think that NC300 engine would swap right out on my K7-CB250F frame with no electrical changes, and the radiator mounts are present on this frame. Here is the K7-NC250 model. They are also showing this as a 6 speed/four valve: I sure would like to see the engine model number stamp on these engines. There is a bigger H7L-NC450, which looks like real fun |
