#361 |
1937 Hudson Terraplane, three on the tree. Found at http://garagejournal.com/forum/showt...t=51567&page=4
#362 |
The original "Bush Car"
#363 |
This was at the pit when my dad was in there I guess, they're trying out the new side dump trailers before sending it up north.
![]() It has 13 axles, 50 tires, and 3 articulation points.
#364 | |
Dom Deluise.......he was awesome ![]() |
#365 | |
Looks like a "Hackberry" tree. I like the X cross frame....looks like that would be a robust design. |
#366 | |
I used to haul explosives to quarries so I've seen plenty of side dumps, but none like that. |
#367 | |
Happy to serve. |
#368 | ||
The 'secret' to such a climb is to start with a high performance airplane, such as a Maule, and gut it of everything not legally required to fly. I would imagine 3 or it's 4 tanks were empty, and it was running off of 5 gallons or so in only one tank. Other factors would be as strong a headwind as they could find, and as cool a day (not too likely in Georgia in the summertime, probably shortly after sunrise) as possible. My Maule and I have had a lot of fun with such antics. 8)
Happy to serve. |
#369 | |
#370 |
These are real pictures, before Photoshop, or PC's for that matter, even existed.
B.D. Maule, the creator of these fine airplanes, is demonstrating the fantastic takeoff performance of a Maule by actually taking off and flying in the hanger before he even reaches the doors! 8O ![]() The plane you can fly right out of the hangar! B.D. Maule shows the short takeoff capabilities of the Maule with this daring exit through the factory doors in the late 60’s. ![]() And again, in the early 70’s, B.D. once again shows off the Maule’s performance. Mr. Maule was the only one who ever attempted this maneuver.
Happy to serve. |
#371 |
That's pretty cool
#372 | ||
#373 |
That's awesome.
Runway......pfff.....who needs a runway....it's like a VSTOL? As far as the Western Star semi truck. Anymore they pretty much just run Detroit motors since they are owned by Freightliner, which right now Detroit offers a 15litre with 560hp and 1850lbs of torque. That looks like a 90's or early 2000's Western Star so it could have a Detroit, Cummins, or Cat motor so I could have a 600hp 2050ftlb engine in it. Having said that it could have an older 425 hp /1450ft lbs Cat 3406b in it. Most of it's in the gearing. Some of the 10,13,18 speed trannys have 12-14 to 1 low gears in them and the 8LL and 15 speeds have 16 to 1 low gear in them. Final drive would probably have an additional splitter on it so it would be something like a 4.33/5.88 split. The truck might have a pumped up engine in it, but most times the pumped up engines put out a lot more horsepower but not much torque gain. Either way a 500hp engine putting out 1600lbs of torque would work as long as the gearing is there. 1600lbs times a 16.1 first gear would be 25600lbs then going thru a split diff at 5.88 would be 150528lbs of torque at the wheel. More then enough torque to propel 150,000 lbs up to 45mph. If additional speed is nessasary then a taller diff would be needed hence the need for a splitter. A 4.33 rear end with a .80 top gear spinning at 1500rpms with 24.5 tires would get you somewhere around 55mph. |
#374 |
I'd imagine they've got more weight on then that though, although it's just a guess. With a tridem truck and 4 axle trailer they pull 63K kgs, this has 5 more axles. I'd imagine it's over 90K kgs? That of course is just a number I pulled out of the air.
I'm also not too familiar with Western Star models, I can't tell that from a brand new one ![]()
#375 |
Here are a few more photographs from Punxsutawney, PA.
![]() ![]() ![]() ![]() Spud ![]()
