05-09-2011, 01:46 PM | #316 |
New cost saving measure. Make yer own.
05-09-2011, 07:45 PM | #317 |
I like it! Wonder how it holds up in the rain though?
05-09-2011, 08:28 PM | #318 | |
05-09-2011, 10:08 PM | #319 |
He should waterproof it with packing tape.
05-10-2011, 07:56 AM | #320 |
I have seen them wrapped in plastic before.
05-13-2011, 07:46 PM | #321 |
New speedo cable installed. I lubed it really well before putting it on and this time made sure I had the bottom end seated all the way. :oops:
Also today I learned that I can change the fuel pump on a honda ruckus in 10 minutes. Honda wanted $85 shop labor to do that. :roll:
05-14-2011, 12:24 AM | #322 |
Is it a simple three barb vacuum pump (meaning one vacuum barb and two fuel barbs)?
05-14-2011, 12:43 AM | #323 | |
05-14-2011, 08:00 AM | #324 | |
05-14-2011, 08:02 AM | #325 | ||
The honda manual says to remove everything from the top side which would probably take an hour. I am sure the tech would have done the same thing as me.
05-15-2011, 04:20 PM | #326 |
Broke down at the office yesterday. Electrical trouble. Believe it is in the switched installed to bypass the keyswitch.
Also the throttle cable has siezed up. Everything was fine when I parked it. At least my boss lives in the same direction.
05-16-2011, 08:55 AM | #327 |
maybe some gremlins took it for a spin while you were working. it has happened to me .
my help may not be the best but it is free+-Seek ye first the kingdom of GOD |
05-31-2011, 04:11 PM | #328 |
Back up and running again.
I now have a keyswitch and a key. Redid some electrical and installed me a 12v power outlet. Installed the old throttle cable after a good cleaner and lubing. It seems to be working just fine now. Took for a test drive and compare the GPS speed to indicated. 2-3mph optimistic. Not bad. Only thing is that I got a switch for the regular elite 150 and not the deluxe. It works, but the doesn't have the wire for the pop up light. I can live with it. The light just stays up. |
05-31-2011, 10:14 PM | #329 |
12 volt outlets are handy, I put one on my KLR so that I can pump the tires back up after going gravel road/ trail riding. Also handy for charging my cell phone
06-01-2011, 12:29 AM | #330 |
I'm glad you got you scoot back up and running, Allen!
You guys are starting to convince me to install a 12-volt outlet on both my bikes. Spud
