#316 | |
#317 |
http://californiascooterco.com/blog/
Seems Joe has been paying attention and has answered most of the questions I had to ask him today. Heading out now. Should be there shortly after hey open. ![]() |
#318 |
X2. Looking forward to your thoughts.
#319 | |
I've watched most of the Twist The Throttle episodes, and this rivals the top Japanese factories.
#320 |
Motomapper on a secret mission to gather info at CSC. Think of the theme from any of the James Bond movies...
#321 |
The air filter is accessed as I suspected. However, I wonder how difficult it is to remove the two plastic pieces which cover the air box? The Silk Road Rider claimed he had to remove luggage in order to access the foam air filter.
![]() ![]() As I also suspected, the forks appear to be the standard, Chinese 37mm forks. If I am correct, these forks should have 6.5 inches of travel, instead of the 5.18 inches of travel reported earlier. Perhaps Joe measured the fork travel by compressing the loaded forks, and allowing them to rebound. I hope this is the case, since the preload on forks is usually 25 percent, and this would account for the extra 1.5 inches of travel available. ![]() ![]()
#322 | |
![]() Joe, what method did you use to obtain the measurement for the fork travel? Also, please confirm you don't need to remove the luggage to access the foam air filter, as reported by the Silk Road Rider. ![]()
#323 |
I checked in the maintenance manual, saw 130mm, and converted to inches.
#324 |
This is somewhat old news, and has been reported earlier on these forums. However, in case you haven't seen them, here are two 'Chinglish' videos describing Zongshen Motorcycle Group, and the Zongshen factory.
#325 |
Here's the second part of the video.
#326 | |
#327 |
Joe, please confirm you don't need to remove the luggage to access the foam air filter, as reported by the Silk Road Rider.
#328 |
Sorry, I missed that part of the question. You do have to remove the trunk and the rack, and the two side panels on the left side of the bike. You don't have to remove the panniers.
#329 | |
![]() Do you need to remove the trunk and rack because of the one bolt circled in blue in the photograph below? ![]()
#330 |
As we say in Baja, Spud, si.
